SOMMERCABLE EPILOGUE RCA Modulation Cable Gold Plated OFC Copper Shielded 2m (Pair)
Sommercable's Epilogue RCA modulation cable has been designed to contribute to a neutral and faithful sound reproduction, favouring a wide sound image thanks to excellent signal transmission. Ideal for sound professionals and recording studios, it is equally effective in a home HiFi system.
Reference : 14414
175,00 €tax incl.
145,83 € tax excl.
Shipping date: 23-04-2025.
Sommercable Epilogue
Sommercable Epilogue Câble de Modulation RCA Cuivre OFC Blindé Plaqué Or 2m (La paire)
Thus, the Epilogue cable integrates high quality components. The sheath conceals 4 conductors in 100% OFC copper with a triple shielding composed of a copper and semiconductor braid in order to limit the impact of interference on the signal. The conductors are smoothed with Carbon for better conductivity. The design of the cable allows it to achieve a very low electrical capacity of 35pF, ensuring that there is virtually no loss over cable lengths of less than 10m.
The RCA connectors of this cable have PTFE insulation and are equipped with a complex shielding. Its contacts are gold plated to ensure very good conductivity and resistance to oxidation.
Product typeModulation cable
ConnectorsRCA
Length2m
Cable diameterØ7mm
Conductors materialOFC Copper
Contacts platingGold
Sheath materialPlastic
Shielding materials3 layers :
Braided Copper and semiconductor
Capacity35pF core/core (crossover)
Cable colorYellow
QuantitySold by pair (2 cables)
Length (m)2.0
ShieldingYes
Section (mm²)N/A
ConnectorRCA
Modèle sonore très neutre, sans décoloration et spatialisation respectée pour une reproduction à la fois détaillée et musicale
Ce câble est globalement neutre, équilibré et linéaire, avec des basses de qualité et un aigu présent mais non envahissant, le médium pourrait être un peu plus "fruité", en tout cas pour la musique classique ou Jazz, sinon très bon pour le rock, la pop. Point particulier : le temps de rodage est étonnement assez long, ensuite le son semble continuer à s'améliorer très longtemps, pour finalement atteindre un très bon niveau de qualité :
- large bande passante.
- grave bien présent mais bien contrôlé
- équilibre global non spectaculaire mais de qualité.
En conclusion, des câbles neutres, transparents et détaillés qui donnent du corps au son et ne diminuent pas la chaleur de ma configuration. Rapport prix et qualité du son très bon, à ce prix, je ne vois rien d’autre. J’utilise le Neotec 3220 qui est un câble assez différent, un peu plus d’ouverture, plus doux, aigu plus défini et cristallin, tendance à être lumineux sur la pop et le rock, voire le Jazz. Dans cette tranche de prix entre 100 et 250 euros, les deux meilleurs rapport qualité sonore et prix.
This review has been posted for SOMMERCABLE EPILOGUE RCA Modulation Cable Gold Plated OFC Copper Shielded 2m (Pair)
Sommercable's Epilogue RCA modulation cable has been designed to contribute to a neutral and faithful sound reproduction, favouring a wide...
