By buying this product you get 23 loyalty points
This Viablue NF-S1 Interconnect cable reproduces music with high fidelity at all frequencies.
It transmits sound linearly and without distortions.
The two Silver-plated shielding screens preserve the most subtle variations of the signal and especially the high frequencies.
Its construction is of symmetrical type, ie it comprises 2 conductors instead of a single one in a coaxial cable.
Each conductor has 19 tinned wires with a diameter of 0.185mm or an equivalent section of 0.5mm².
The quadruple shielding consists of 2 films of ALU-PETP (Polyethylene terephthalate) and 2 silver-plated braids inverted to each other.
Cand superimposing different shields ensures a 100% overlap.
The outer diameter of the NF-S1 is 8mm
Viablue cables are equipped with gold-plated XLS connectors and insulated Teflon.
Capacity between 2 conductors: 50 pF core / core
Capacity between conductors and shield: 100 pF core / screen
Length (m) | 0.5 |
Shielding | Yes |
Section (mm²) | 0.50 |
Connector | RCA |
Conductors material (Cable) | Copper |
Conductors Plating (Cable) | None |
Average votes 4.3 / 5 3 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Frank T.
Marc F.
