By buying this product you get 23 loyalty points
Neotech's NEI-3001G is a balanced RCA to XLR cable incorporating four G-UPOCC composite conductors, a combination of OCC copper and graphene. This new conductor marks a significant advance, both in terms of research and industrial applications. The addition of graphene improves the stability of electrical signal transmission at high temperatures, while preserving the exceptional conductivity of OCC copper, so that performance remains intact, even at high voltages.
The conductors are insulated with polyethylene foam, preventing any transmission of electrical discharge with the double shielding of aluminum mylar and braided copper, while giving the cable good mechanical strength. Finally, this cable is completed by an OFC copper RCA connector and a copper alloy XLR connector, both of which have been cryogenically treated to strengthen their molecular bonds and therefore their conductivity.
Product type | RCA/XLR cable |
Length | 0.5m |
Connectors | Male RCA Male 3-pins XLR |
Conductors material | G-UPOCC Copper |
Insulation | Polyethylene foam (PE) |
Shielding | Aluminum mylar Braided copper |
Outer sheath | PVC |
Connectors contacts material | OFC Copper Copper alloy |
Connectors contacts plating | Gold |
Color | Blue |
Package | Sold by pair |
Length (m) | 0.5 |
Shielding | Yes |
Section (mm²) | N/A |
Connector | RCA |
Connector | XLR |
Conductors material (Cable) | Copper |
Conductors material (Cable) | Graphene |
Conductors Plating (Cable) | None |
