VIABLUE NF-S1 Mono Female XLR Femelle to Male RCA Cable 0.5m (Pair)
The ultimate goal of any high-end HiFi cable is to transmit the audio signal in the cleanest and most efficient way to provide the most faithful audio message possible. To achieve this, the Viablue NF-S1 XLR female to RCA male mono cable uses high-end materials to promote a detailed and transparent sound reproduction.
Reference : 16024
248,00 €tax incl.
206,67 € tax excl.
Viablue NF-S1
The ultimate goal of any high-end HiFi cable is to transmit the audio signal in the cleanest and most efficient way to provide the most faithful audio message possible. To achieve this, the Viablue NF-S1 XLR female to RCA male mono cable uses high-end materials to promote a detailed and transparent sound reproduction. It integrates two tinned OFC copper conductors, each composed of 19 strands of 0.19mm and insulated by a polyethylene sheath. Then comes a quadruple shielding, composed of two silver spirals and two aluminum-PET sheets. The connectors are not left out with a 24 carat gold plating to maintain excellent conductivity while protecting them from oxidation. The cable also incorporates a ferrite to filter out interference.
Product typeXLR to RCA cable
ConnectorsFemale XLR
Male RCA
Length0.5m
Conductors materialTinned OFC Copper
InsulationPolyethylene
Shielding2x Silver Spirals
2x Aluminum-PET foils
Connectors contacts platingGold 24k
Outer diameterØ9.5mm
FerriteØ20mm
CapacityConductor : 50pF/m
Screen : 100pF/m
QuantityPair (2 cables)
Length (m)0.5
ShieldingYes
Section (mm²)N/A
ConnectorRCA
ConnectorXLR
The ultimate goal of any high-end HiFi cable is to transmit the audio signal in the cleanest and most efficient way to provide the most faithful...
