VIABLUE NF-S1 Mono Female XLR Femelle to Male RCA Cable 1m (Pair)
The ultimate goal of any high-end HiFi cable is to transmit the audio signal in the cleanest and most efficient way to provide the most faithful audio message possible. To achieve this, the Viablue NF-S1 XLR female to RCA male mono cable uses high-end materials to promote a detailed and transparent sound reproduction.
By buying this product you get 30 loyalty points
Reference : 16025
302,99 €tax incl.
252,49 € tax excl.
Viablue NF-S1
Viablue NF-S1 Câble XLR Femelle vers RCA Mâle Mono 0.5m (La paire)
The ultimate goal of any high-end HiFi cable is to transmit the audio signal in the cleanest and most efficient way to provide the most faithful audio message possible. To achieve this, the Viablue NF-S1 XLR female to RCA male mono cable uses high-end materials to promote a detailed and transparent sound reproduction. It integrates two tinned OFC copper conductors, each composed of 19 strands of 0.19mm and insulated by a polyethylene sheath. Then comes a quadruple shielding, composed of two silver spirals and two aluminum-PET sheets. The connectors are not left out with a 24 carat gold plating to maintain excellent conductivity while protecting them from oxidation. The cable also incorporates a ferrite to filter out interference.
Product typeXLR to RCA cable
ConnectorsFemale XLR
Male RCA
Length1m
Conductors materialTinned OFC Copper
InsulationPolyethylene
Shielding2x Silver Spirals
2x Aluminum-PET foils
Connectors contacts platingGold 24k
Outer diameterØ9.5mm
FerriteØ20mm
CapacityConductor : 50pF/m
Screen : 100pF/m
QuantityPair (2 cables)
Length (m)1.0
ShieldingYes
Section (mm²)N/A
ConnectorXLR
ConnectorRCA
Un câble avec un son clair, ouvert et dynamique
Le rapport qualité/prix est bon avec ce câble (un peu cher quand il est monté en version au mètre, c’est plus attractif), la qualité de fabrication est très bonne, le blindage est excellent.
Le Viablue NF-S1 XLR-RCA a une tonalité légèrement claire, ce n’est pas sombre ou trop lumineux. Il présente les voix de manière assez forte. Celles-ci sont également plus proches et moins douces que certaines autres références (je pense à Néotech ou Cardas). Les chansons sont restituées de manière assez émouvantes. Les basses sont puissantes. On peut dire que Viablue a donné un coup de boost à ma musique. La basse est profonde et épanouissante. La dynamique est également satisfaisante.
C’est un câble intéressant pour présenter un son spacieux et crédible dans tous les styles de musique. Ce n’est pas artificiel, il crée une atmosphère riche entre les chanteurs et les instruments. Le son relativement doux et arrondi malgré une certaine vivacité garantit une expérience d’écoute agréable. Il modifie peu le son original, c’est neutre. En négatif, par rapport à des câbles plus haut en gamme, on peut regretter des hautes fréquences manquant d’expressivité et davantage de transparence.
This review has been posted for VIABLUE NF-S1 Mono Female XLR Femelle to Male RCA Cable 1m (Pair)
The ultimate goal of any high-end HiFi cable is to transmit the audio signal in the cleanest and most efficient way to provide the most faithful...
