SOMMERCABLE MEDIALINE HI-CM06 Component Cable YUV 5m
Reference : 2624
76,90 €tax incl.
64,08 € tax excl.
Sommercable Cable YUV 1m
Medialine Cable - HI-CM06 Connectors
A YUV cable is composed of three asymmetrical 75 Ohm single conductors.
It is mainly used for video connections (eg "progressive scan" projectors) and for connecting DVD players.
The signals of the YUV standard must be memorized, and it is obvious that they must not be erroneous or transformed before being transmitted to the receiver devices.
Thestandard YUV can also be used for the retransmission of "progressive PAL / NTSC" signals.
For retransmission in HDTV format, we recommend using the VECTOR cable specially designed for this purpose.
For the perfect maintenance of the image signals, it is advisable not to exceed a retransmission length of more than 20 m.
If this distance is to be exceeded, we recommend the use of the TRANSIT 3 meter cable, which can be used up to a distance of more than 50 m.
We offer YUV cables in two different versions:
The first version based on the round and very flexible MEDIALINE cable, equipped with golden cinch connectors HICON HI-CM06, with insulation in Delrin;
The other variant composed of flat cable ALTERA SPLIT and HICON HI-CM01C Cinch connectors, with gold-plated crimp connectors, Teflon insulation and anti-crease sleeve.
This second variant is very well adapted to the YUV uses, because compared to a welded connection, a crimped connection always has a low resistance value of contact
The connection between cable and plug is practically free of loss.
Thee cable ALTERA SPLIT is delivered in a representation box in the form of a film bobbinot!
USE :
  • DVD player connection and "progressive PAL / NTSC" signal transmission
ADVANTAGES :
Length (m)5.0
