VIABLUE TVR 2.0 Coaxial Antenna Cable 2.5m
Reference : 6317
54,99 €tax incl.
45,82 € tax excl.
Shipping date: 16-04-2025.
Featuring optimal shielding technology, the ViaBlue TVR 2.0 antenna cable is suitable for digital transmissions with 75Ohm impedance and a lossless signal-to-noise ratio of 120dB. It allows the transmission of an audio/video stream with the best possible quality for a perfect result.
With its 4 shielding screens, the coverage reaches without problem 100% and thus protects the signal from interference caused by devices emitting waves such as telephones, microwave, Wifi access point... The inner conductor is insulated with polyethylene.
In addition, induced currents that could occur between the conductor and the shield are eliminated by the ferrite cores placed at the ends. Viablue TVR 2.0 cables are assembled with Viablue T6S high-end connectors, which allow a very low contact resistance thanks to an optimal shape and a gold-plated coating. The 100% shielding is maintained to the end by the copper connector housing.
The cord has a Male and a Female connector
Features:
  • Outer diameter: 9mm
  • Connectors: T6s antenna connectors
  • Finish: Silver plated
  • High purity OFC Copper
https://www.audiophonics.fr/images/viablue_antenne-120db-ant.gif
ViaBlue Cobrageflechtschlauch Schutzüberzughttps://www.audiophonics.fr/images2/7024/7024_VIABLUE_TVR2.0_SILVER_1.jpghttps://www.audiophonics.fr/images2/6320/6320_viablue_TVR-2_connecteur_1.jpg
Length (m)2.5
ShieldingYes
Section (mm²)N/A
ConnectorAntenna connector
bonjour
la différence de qualité d'image sur les chaînes TNT HD est évidente
je ne regrette pas mon achat
This review has been posted for VIABLUE TVR 2.0 Coaxial Antenna Cable 2.5m
