VIABLUE TVR 2.0 Coaxial Satellite Type F Cable 1m
Reference : 6321
69,90 €tax incl.
58,25 € tax excl.
Featuring optimal shielding technology, the ViaBlue TVR 2.0 satellite cable is suitable for digital transmissions with 75Ohm impedance and a lossless signal-to-noise ratio of 120dB. It allows the transmission of an audio/video stream with the best possible quality for a perfect result. This cable is used to connect high quality devices like TVs, VCRs or tuners, or with F-plugs, satellite demodulators.
With its 4 shielding screens, the coverage reaches without problem 100% and thus protects the signal from interference caused by devices emitting waves such as telephones, microwave, Wifi access point... The inner conductor is insulated with polyethylene.
In addition, induced currents that could occur between the conductor and the shielding are eliminated by the ferrite cores placed at the ends. Viablue TVR cables are assembled with Viablue T6S high-end connectors which allow a very low contact resistance thanks to an optimal shape and a gold plated coating. The 100% shielding is maintained to the end by the copper connector housing.
Features:
  • Outer diameter: 9mm
  • Connectors: Type F, T6s plug
  • Silver plated finish
  • High purity OFC Copper
https://www.audiophonics.fr/images/6320_VIABLUETVR150DBSAT.gif
ViaBlue Cobrageflechtschlauch Schutzüberzughttps://www.audiophonics.fr/images2/7024/7024_VIABLUE_TVR2.0_SILVER_1.jpghttps://www.audiophonics.fr/images2/6315/6314_VIABLUETVR150DB_3.jpg
Length (m)1.0
ShieldingYes
Section (mm²)N/A
ConnectorType F (CEE 7/3 - CEE 7/4)
