1877PHONO HEMI-X XLR to 2x Mini XLR Headphone Cable OCC Copper Shielding 1.5m
The 1877Phono Hemi-X is a high-end headset cable. It includes a XLR connector on the one hand and two Mini XLRs on the other, each of which of course has gold-plated contacts. The entire cable benefits from a flawless design quality, including OCC Copper conductors for optimal signal conductivity.
Reference : 13858
219,00 €tax incl.
182,50 € tax excl.
1877Phono Hemi-X
1877Phono Hemi-X Câble Casque Jack 6.35mm vers 2x Mini XLR Cuivre OCC Blindage 1.5m
The 1877Phono Hemi-X is a high-end headset cable. It includes a XLR connector on the one hand and two Mini XLRs on the other, each of which of course has gold-plated contacts. The entire cable benefits from a flawless design quality, including OCC Copper conductors for optimal signal conductivity. Double shielding drastically reduces the impact of interference and therefore the noise that could affect the playback of your music. The latter consists of a Mylar Aluminium sheet and braided Copper. Finally, the cable is subjected to a double treatment to further increase its performance: Deep Cryo and Ultra Sonic 7.
Deep Cryo Treatment
Each conductor undergoes a Deep Cryo treatment. This consists in cooling the conductors between -186°C and -196°C. To define the exact temperature at which conductors must descend, 1877Phono studied the purity, size and molecular structure of each conductor. This treatment allows to obtain more convincing silences, to improve the bandwidth or the dynamics.
1877Phono Hemi-X Traitement Deep Cryo
1877Phono Hemi-X Traitement Ultra Sonic 7
Ultra Sonic 7 Treatment
This is a two-step process. First, the bare conductor passed through a ceramic mold into an ultrasonic cleaning chamber. This process removes impurities and imperfections from the yarn surface down to the molecular level. Once each yarn has been processed, they are grouped together in bundles for a new treatment. During this second step, the voltage is increased while remaining below the conductor threshold. This adjustment provides a running-in effect in addition to the 30 to 40 hours of signal and/or current that each cable receives. Ultra Sonic 7 and Deep Cryo treatments prepare the cable to break in in a few days rather than several months once at the user's premises.
Product typeMale XLR to 2x Mini XLR Cable
Length1.5m
Conductors materialOCC Copper
DielectricHDPE
TreatmentsUltra Sonic 7
Deep Cryo
ShieldingMylar Aluminium Foil
Braided Copper
Connectors contacts platingGold
External sheathMicro Monofilament Polyester Anti-Static
ColorCable : Red and black
Connectors / Splitter : Rose gold
Length (m)1.5
ShieldingYes
Section (mm²)N/A
ConnectorXLR
ConnectorMini XLR
The 1877Phono Hemi-X is a high-end headset cable. It includes a XLR connector on the one hand and two Mini XLRs on the other, each of which of...
