Balanced Interconnect Cable Male Jack 6.35mm TRS to Female XLR 3-Pole OFC Copper 75cm (Pair)
These affordable cables are balanced 6.35mm TRS Male to XLR 3-Pole Female interconnect cables. They are shielded and the conductors are made of 99.99% pure 4N OFC copper for increased conductivity and a clear signal.
Reference : 18370
7,90 €tax incl.
6,58 € tax excl.
Shipping date: 29-04-2025.
Balanced Interconnect Cable 6.35mm TRS Male to XLR 3-Pole Female OFC Copper 75cm (Pair)
These affordable cables are balanced male Jack 6.35mm TRS to female XLR 3-pole interconnect cables. They are shielded and the conductors are made of 99.99% pure 4N OFC copper for increased conductivity. The contacts of the Jack 6.35mm and 3-pin XLR connectors are gold-plated, and the internal soldering is made with a solder material including 3% high-purity silver for resistance to corrosion and oxidation. These modulation cables can easily find a place in your Hi-Fi installation or for use with microphones. They have a length of 75cm.
Product typeBalanced interconnect cable
Connectors6.35mm TRS male jack
XLR 3-pole female
Length75cm
Câble external diameterØ6mm
Conductors material4N OFC Copper (99.99% pur)
Connectors contact platingGold
Extrernal sheathPVC
Shielding
Weight / cable75g
PackageSold by pair
Length (m)0.75
ShieldingYes
Section (mm²)N/A
ConnectorXLR
ConnectorJack 6.35mm
TRES BONS câbles
Utilisés avec mon DAC TOPPING E70 VELVET: parfaits !
This review has been posted for Balanced Interconnect Cable Male Jack 6.35mm TRS to Female XLR 3-Pole OFC Copper 75cm (Pair)
These affordable cables are balanced 6.35mm TRS Male to XLR 3-Pole Female interconnect cables. They...
