MEZE Jack 2.5mm to 2x Mini XLR Balanced Interconnect Cable Silver Plated PCUHD Copper 1.3m
This balanced Meze cable was specifically designed for use with headphones. It features an exceptional design, using silver-plated Furukawa PCUHD copper conductors, ensuring incredible electrical conductivity for perfect audio signal transmission. Furukawa cables are known for their ability to provide open, yet highly detailed sound with perfectly controlled transients and punchy bass.
By buying this product you get 39 loyalty points
Reference : 16503
399,00 €tax incl.
332,50 € tax excl.
Shipping date: 15-04-2025.
Meze Headphone cable
2x Mini XLR to Jack 2.5mm Balanced Silver Plated PCUHD Copper 1.3m
Meze Câble pour casque 2x Mini XLR vers Jack 2.5mm Symétrique Cuivre PCUHD Plaqué Argent 1.3m
By combining a molding process with a post-treatment that does not use hot extrusion or lamination, no impurities corrupt the conductors. Also, no gas burners are used in the manufacturing process to ensure that the oxygen level in the copper is perfectly controlled, as it is measured at 5ppm, which is lower than the standard required for OFC (Oxygen Free Copper).
Regarding the connectivity of this cable, it has two Mini XLR connectors and a 2.5mm jack connector, allowing a balanced connection. Each connector is equipped with gold-plated contacts, to maintain excellent conductivity and durability.
Product typeHeadphone balanced cable
Length1.3m
Connectors2x Mini XLR 4 pins
1x Jack 2.5mm
Cable conductors materialPCUHD Copper
Cable conductors platingSilver
Conductors composition140*0.04mm
Sheath materialTPE
SolderingJensen Silver 4%
Length (m)1.3
ShieldingNC
Section (mm²)N/A
ConnectorJack 2.5mm
ConnectorMini XLR
This balanced Meze cable was specifically designed for use with headphones. It features an exceptional design, using silver-plated Furukawa PCUHD...
