MEZE Jack 6.35mm to 2x Mini XLR Interconnect Cable PCUHD Copper 2.5m
This Meze cable was specifically designed for use with headphones. It features an exceptional design, using Furukawa PCUHD copper conductors, ensuring incredible electrical conductivity for perfect audio signal transmission. Furukawa cables are known for their ability to provide open, yet highly detailed sound with perfectly controlled transients and punchy bass.
By buying this product you get 34 loyalty points
Reference : 16510
349,00 €tax incl.
290,83 € tax excl.
Shipping date: 15-04-2025.
Meze Headphone Cable
2x Mini XLR to Jack 6.35mm PCUHD Copper 2.5m
Meze Câble pour casque 2x Mini XLR vers XLR 4 Pins Symétrique Cuivre PCUHD 1.3m
By combining a molding process with a post-treatment that does not use hot extrusion or lamination, no impurities corrupt the conductors. Also, no gas burners are used in the manufacturing process to ensure that the oxygen level in the copper is perfectly controlled, as it is measured at 5ppm, which is lower than the standard required for OFC (Oxygen Free Copper).
Regarding the connectivity of this cable, it has two Mini XLR connectors and a Jack 6.35mm connector. Each connector is equipped with gold-plated contacts, to maintain excellent conductivity and durability.
Product typeHeadphone cable
Length2.5m
Connectors2x Jack 6.35mm
1x Jack 4.4mm
Cable conductors materialPCUHD Copper
Cable conductors materialSilver
Conductors composition140*0.04mm
Sheath materialTPE
SolderingJensen Silver 4%
Length (m)2.5
ShieldingNC
Section (mm²)N/A
ConnectorMini XLR
ConnectorJack 6.35mm
This Meze cable was specifically designed for use with headphones. It features an exceptional design, using Furukawa PCUHD copper conductors,...
