OYAIDE HPSC-X63 Jack 6.35mm to Mini XLR 3 Poles Headphone Cable 1.3m
This high-end Oyaide HPSC-X63 cable has a 6.35 jack connector and a 3-pin Mini XLR connector. It has mainly been designed to replace defective or inferior cables on headsets with this type of connector, such as the AKG K712PRO, Pioneer HDJ-2000, etc.
Reference : 13517
99,00 €tax incl.
82,50 € tax excl.
Shipping date: 16-04-2025.
Oyaide HPSC-X63
Oyaide HPSC-X63 Câble Casque Jack 6.35mm vers Mini XLR 3 Pôles Noir
102 SSC Conductors
The cable integrates two 102 SSC high purity braided copper conductors, with a 7/7/0.089 configuration. The 102 SSC is the result of extremely controlled machining, resulting in a very high IACS rate of 102.3%. To avoid contamination of the Copper by impurities, Oyaide uses only non-recycled Copper. To go further, the conductor undergoes a mechanical treatment specific to the design proposed by Oyaide, making it possible to remove any impurity or defect. The conductor is finally annealed twice.
xxx
xxx
Insulation, shielding and sheath
These two 102 SSC conductors are covered with TPE insulation and then with 102 SSC copper shielding, with an intermediate silk filling. The shielding is then covered with a second layer of TPE insulation, then with a braided black and white silk sheath of the most beautiful effect and covering 100% of the cable. The latter has the advantage of avoiding static electricity charging and thus limiting noise on the signal.
Product typeJack 6.35mm to Mini XLR 3 poles Headphone cable
Length1.3m
External diameter4mm
Connectors platingMini XLR : Gold plated
Jack 6.35mm TRS : Silver + Rhodium plated
Conductors2x 102 SSC Copper conductors (7/7/0.089)
InsulationTPE + Silk
Shielding102 SSC Copper (58/0.089)
SheathBraided Silk
Compatibility (non-exhaustive list)AKG : K712 PRO, K702, K702 65th, Q701, K271 Studio, K271 MKI I, K240 Studio, K240 MKII, K181 DJ, K181 DJ UE, K171 Studio, K171 MKII, K141
Pioneer : HDJ-2000, HDJ-2000 MK2
ADL : H118, J128
Electrical resistanceConductors : Max. 67.9 Ohm/km
Insulation : Min. 1 MOhm/km
ColorBlack and white
Length (m)1.3
ShieldingYes
Section (mm²)N/A
ConnectorMini XLR
ConnectorJack 6.35mm
This high-end Oyaide HPSC-X63 cable has a 6.35 jack connector and a 3-pin Mini XLR connector. It has mainly been designed to replace defective or...
