This XLR male to XLR female modulation cable has a nice design quality, using a Canare L-4E6S cable. The cable has copper conductors insulated with PE jackets and is shielded with copper braid to effectively reject EMI/RFI interference.
This XLR female to XLR male modulation cable offers very good performance at a low price. It has a conductor cross-section of 1.31mm², is shielded and has gold-plated contacts. It ensures very good conductivity and durability, while cancelling interference that can impact signal integrity.
This KAIBOER XLR interconnect cable is an XLR male to XLR female interconnect cable. It features pure 4N silver conductors and a 2x 8-strand litz wire structure for maximum conductivity. In addition, the XLR connector contacts are 3u gold-plated for corrosion and oxidation resistance.
This KAIBOER XLR interconnect cable is a male XLR to female XLR cable. The conductors of this cable are made of silver-plated OFC pure copper, and the contacts of the XLR connectors are 24k gold-plated. This allows the entire cable to offer maximum conductivity, while at the same time providing resistance to corrosion and oxidation at the XLR...
The Neotech NEMOI-3220 modulation cables combine PTFE insulation and pure OCC copper conductors with a rectangular cross-section, and are equipped with a particular architecture, allowing a strong reduction of the effect of inductance and capacitance. The result is surprising, revealing qualities often considered contradictory such as a good bass, a...
PANGEA cables benefit from technologies rarely encountered in this range. An excellent alternative to the market leaders offering high quality affordable design, the first obvious choice for a quality cable.
PANGEA cables benefit from technologies rarely encountered in this range. An excellent alternative to the market leaders offering high quality affordable design, the first obvious choice for a quality cable.Strengths:Real balanced cable with 3 conductors plus groundHigh-end finishHigh resistance XLR plug
This Pangea Premier SE Balanced XLR cable is exceptionally well made, with Cardas Grade One copper strands (on the hot end) considered the best copper available. It is shielded by silver-plated EMI / RFI insulation and aluminum mylar.
This Pangea Premier XL Balanced XLR-to-XLR modulation cable features exceptional workmanship. It features Cardas Grade one copper strands with PE tube insulation and Al Mylar aluminum foil shielding, silver-plated braided copper and carbon-filled PE tube. The triple-layer shielding gives this cable effective protection against RFI noise and EMI interference.
This high quality XLR cable pair consists of a Sommercable Epilogue modulation cable and Neutrik connectors, specially designed for optimal signal transmission. The cable integrates insulated and shielded conductors. In addition, each core undergoes a special carbon smoothing to improve conductivity.
TCX1 cables from Topping are high quality XLR male/female cables. They incorporate 6N Copper and Silver plated 6N Copper conductors for perfect signal transmission.
