AUDIOPHONICS NEUTRIK Interconnect Cable Signal Splitter 1x XLR Female 3 Pins to 2x XLR Male 3 Pins 30cm
This Audiophonics Neutrik cable is a 3-pin XLR female to 2x 3-pin XLR male signal splitter. This cable is therefore ideal for doubling a balanced signal from the female connector to the male XLR splitters connectors.
Reference : 18373
35,90 €tax incl.
29,92 € tax excl.
Shipping date: 22-04-2025.
AUDIOPHONICS NEUTRIK Câble de modulation Doubleur de Signal 1x XLR Femelle 3 Pins vers 2x XLR Mâle 3 Pins 30cm
This Audiophonics Neutrik cable is a 3-pin female XLR to 2x 3-pins male XLR signal splitter. The cable used is a Mogami Neglex W3106, with a total diameter of 2x Ø4.8mm and two conductors with a cross-section of 0.22mm² (AWG24). The Mogami Neglex W3016 is shielded with braided copper and also insulated with XLPE (Cross-Linked Polyethylene). The XLR connectors are 3-pole Neutrik NC3MXX-B and NC3FXX-B connectors with gold-plated contacts for corrosion and oxidation resistance, as well as enhanced conductivity. This cable is therefore ideal for doubling a balanced signal from the female connector to the male XLR splitters connectors.
Product typeInterconnect cable / Signal splitter
Connectors1x XLR Female 3-pole
2x XLR Male 3-pole
Conductor materialCopper
ShieldingBraided copper
InsulationXLPE (Cross-Linked Polyethylene)
Connectors contact platingGold
External sheathPVC
Length30cm
Total diameter2x Ø4.8mm
Weight110g
Package1x  Interconnect cable signal splitter
Length (m)0.3
ShieldingYes
Section (mm²)0.22
ConnectorXLR
This Audiophonics Neutrik cable is a 3-pin XLR female to 2x 3-pin XLR male signal splitter. This cable is...
