By buying this product you get 54 loyalty points
This top-quality Oyaide Tunami Terzo XX V2 XLR modulation cable is assembled with FOCUS 1 connectors, renowned for their excellence and making Oyaide a serious competitor to the leading cable brands. The 102SSC conductor, the flagship of the Oyaide range, is a new-generation copper cable, Virgin Copper 102SSC, made from virgin, non-recycled copper. Each 102SSC conductor undergoes a rigorous double annealing and mechanical polishing process, guaranteeing exceptional internal and surface purity.
Silver-plated copper braid shielding ensures long-lasting stability and optimum electrical and mechanical performance over time.
The Tunami Terzo XX V2 is an XLR cable designed for demanding audiophiles looking for lossless audio transmission and exemplary neutrality across the entire bandwidth, for absolute musicality. The result lives up to its highly technical design: a high-resolution cable offering a perfect balance between definition and timbre.
Oyaide applies a rigorous approach to the manufacture of every cable, combining optimized engineering solutions, superior materials and precise manufacturing processes, all complemented by meticulous craftsmanship.
Product type | XLR interconnect cable |
Connectors | 2x XLR male (FOCUS1) 2x XLR female (FOCUS1) |
Length | 1m |
Cable conductor material | 102SSC copper |
Cable conductors section | 1.25mm² (16AWG) |
Shielding | 1st layer: electromagnetic wave absorber (amorphous polyolefin) 2nd layer: Copper foil tape Layer 3: 102SSC copper braid (160 /0.12mm) |
Insulation | Polymeric Polyolefin |
External sheath | Polyurethane |
Package | Sold by pair |
Length (m) | 1.0 |
Shielding | Yes |
Section (mm²) | 1.25 |
Connector | XLR |
Conductors material (Cable) | Copper |
Conductors Plating (Cable) | None |
