By buying this product you get 59 loyalty points
This very high quality modulation cable is assembled with the most renowned FOCUS 1 connectors, Oyaide has become a competitor of the best brands of connectors. The 102SSC is the new high-end cable from the Oyaide manufacturer, specializing in high-end drivers. This cable is presented with a new generation Copper conductor, named Virgin Copper 102SSC, made of unreclaimed virgin copper. Each conductor 102SSC is annealed twice and then treated by mechanical polishing ensuring a perfect internal and surface purity.
Shieldingby silver plated copper strip ensures long-term stability for optimum electrical and mechanical characteristics over time.
TheTunami Terzo XX V2 is an XLR cable developed for music lovers looking for lossless quality and great neutrality over the bandwidth for a great musicality above all. The result is the highly technical design: a high resolution cable, a perfect balance between definition and timbre.
Oyaimanufactures each cable in the same way, optimized engineering solutions applied to materials and manufacturing processes, complemented by meticulous craftsmanship.
CCharacteristics:
Length (m) | 1.3 |
Shielding | Yes |
Section (mm²) | N/A |
Connector | XLR |
Conductors material (Cable) | Copper |
Conductors Plating (Cable) | None |
