PANGEA PREMIER SE BALANCED XLR Modulation Cable Balanced 0.6m (Pair)
PANGEA cables benefit from technologies rarely encountered in this range. An excellent alternative to the market leaders offering high quality affordable design, the first obvious choice for a quality cable.
Reference : 14091
129,00 €tax incl.
107,50 € tax excl.
True Balanced cable structure
Pangea Premier SE Balanced cable picture
This cable is exceptionally manufactured with Cardas Grade one copper strands (hot spot) considered to be the best copper on earth and shielded with EMI / RFI silver and aluminium mylar plated insulation. In addition, these high-purity copper strands are sheathed in PE tubes using air as natural insulation derived from Pangea's premium cables. The topology of this cable is really symmetrical "Balanced" with three conductors plus a separate ground and not two conductors and a separate ground as on the cables falsely symmetrical.
XLR cards with Carbon Black finish
A good cable is nothing without good XLR plugs and high quality contact quality. Particular care is taken in terms of contacts to its XLR plugs with gold-plated pins and a top-of-the-range "Black Carbon" finish.
Pangea Premier SE True Balanced Câble de Modulation XLR Symétrique
SpEcifications
Conductor typePur Cardas Grade One Copper (Hot point)
OFC 100% Copper (Cold point)
InsulationPE AIR TUBE
EMI / RFI shieldInsulation with Aluminium Mylar Silver plated foil
Sheath materialHigh-strength thermoplastic sheath
Contacts platingGold
Soldering typeHand made
Lenght0.6m
PackageThe pair
Length (m)0.6
ShieldingYes
Section (mm²)N/A
ConnectorXLR
Conductors material (Cable)Cardas Copper
2 reviews
Un régale
Ce cable est bien meilleur qu'une paire de RCA Atlas Element, c'est ma seul référence.
Je vous le conseille
Puis suivant les topologie de préampli/ampli c'est conseiller de passer sur du XLR.
Il offre Plus de dynamique
Un fond beacoup plus silencieux - j'entend plus aucun bruit parasite en fond.
J'entend tout les échos et réverbération des enregistrement.
Pour "juste un cable XLR" c'est beacoup d'apport en qualité audio.
This review has been posted for PANGEA PREMIER SE BALANCED XLR Modulation Cable Balanced 0.6m (Pair)
Excellent
Très bon câble de modulation tant en qualité de fabrication qu’en restitution totalement transparente.
PANGEA cables benefit from technologies rarely encountered in this range. An excellent alternative to the market leaders offering high quality...
