XLR Modulation Cable Balanced 2m (A pair)
This cable is exceptionally manufactured with Cardas Grade one copper strands (hot spot) considered to be the best copper on earth and shielded with EMI / RFI silver and aluminium mylar plated insulation. In addition, these high-purity copper strands are sheathed in PE tubes using air as natural insulation derived from Pangea's premium cables. The topology of this cable is really symmetrical "Balanced" with three conductors plus a separate ground and not two conductors and a separate ground as on the cables falsely symmetrical.
A good cable is nothing without good XLR plugs and high quality contact quality. Particular care is taken in terms of contacts to its XLR plugs with gold-plated pins and a top-of-the-range "Black Carbon" finish.
Spécifications | |
Conductor type | Pur Copper Cardas Grade One ( Hot point ) OFC 100 % copper ( cold point ) |
Isulation | PE AIR TUBE |
EMI / RFI shield | Insulation with aluminium mylar silver-plated foil |
Jacket type | High-strength thermoplastic case |
RCA conductor | Plated Gold PIN high quality finish |
Soldering type | Hand made assembled |
Lenght | 2m |
Package | The pair |
Length (m) |
Shielding |
Section (mm²) |
Connector |
Conductors material (Cable) |
Conductors Plating (Cable) |
