PANGEA PREMIER SE BALANCED XLR-XLR Balanced Interconnect Cable 1.5m (Pair)
This Pangea Premier SE Balanced XLR cable is exceptionally well made, with Cardas Grade One copper strands (on the hot end) considered the best copper available. It is shielded by silver-plated EMI / RFI insulation and aluminum mylar.
Reference : 17893
179,00 €tax incl.
149,17 € tax excl.
Shipping date: 22-04-2025.
PANGEA Premier se BALANCED
Pangea Premier SE True Balanced Câble XLR Symétrique 1.5m
This Pangea Premier SE Balanced XLR cable is exceptionally well made, with Cardas Grade One copper strands (on the hot end) considered the best copper available. It is shielded by silver-plated EMI / RFI insulation and aluminum mylar. What's more, these high-purity copper strands are sheathed in PE tubes using air as a natural insulator, a design derived from the brand's top-of-the-range cables. The architecture of this cable is totally balanced, with three conductors plus a separate ground.
XLR connectors in Black Carbon finish
A good cable is nothing without good connectors. The Pangea Premier SE Balanced uses XLR connectors ensuring high contact quality and excellent strength, with gold-plated contacts. The Black Carbon finish gives this cable a superb aesthetic appearance.
Product typeXLR cables
Cable conductors materialPositive: Cardas Grade One Copper
Negative: OFC Copper
Cable insulationPE + Air tube
Cable EMI / RFI shieldingSilver plated foil + Aluminum mylar
Cable sheathHigh-strength thermoplastic sheath
Connectors contacts platingGold
ConceptionHand-welded and hand-assembled cable
Length1.5m
QuantityPair
Length (m)1.5
ShieldingYes
Section (mm²)N/A
ConnectorXLR
Conductors material (Cable)Cardas Copper
cable LXR modulation
Très bon câble ,équilibré
This review has been posted for PANGEA PREMIER SE BALANCED XLR-XLR Balanced Interconnect Cable 1.5m (Pair)
This Pangea Premier SE Balanced XLR cable is exceptionally well made, with Cardas Grade One copper strands (on the hot end) considered the best...
