TOPPING TCX1 XLR Interconnect Cables 25cm (Pair)
TCX1 cables from Topping are high quality XLR male/female cables. They incorporate 6N Copper and Silver plated 6N Copper conductors for perfect signal transmission.
4.4 / 5
Reference : 14967
49,00 €tax incl.
40,83 € tax excl.
Shipping date: 22-04-2025.
Topping TCX1
Topping TCX1 Câbles de Modulation XLR 25cm (La paire)
TCX1 cables from Topping are high quality XLR male/female cables. They incorporate 6N Copper and Silver plated 6N Copper conductors for perfect signal transmission. Each conductor has a cross section of 0.533mm² (19AWG). The contacts of the connectors are gold plated to maintain excellent conductivity while ensuring high resistance to oxidation. Each cable has a beautiful and robust black and red braided nylon sheath.
Product typeXLR Cables
Connectors1x Male XLR 3 poles
1x Female XLR 3 poles
Length25cm
Cable overall diameterØ8mm
Conductors materialCopper
Silver plated Copper
Conductors section0.533mm² (19AWG)
Connectors contacts platingGold
Covering sheathBraided Nylon
ColorBlack and red
QuantitySold by pair (1 cable with red rings, 1 cable with black rings)
Length (m)0.25
ShieldingNC
Section (mm²)0.533
ConnectorXLR
5 reviews
décevant
acheté pour relier un dac gustard et un ampli casque de la même marque, il m'a fallu un certain temps avant de me dire que quelque chose "clochais", le son était plat et manquais singuliérement de quelque chose, aprés avoir interverti les topping avec des cables diy de marque elecaudio, je retrouve toute l'ampleur et la suavité du son digne de ce genre de matériel.
j'avoue ne pas avoir d'explication a ça, franchement décevant au vu du prix de ces cordons de seulement 25cms a priori qualitatif, les elecaudio de 2x1m ont couté a peine plus cher.
This review has been posted for TOPPING TCX1 XLR Interconnect Cables 25cm (Pair)
Excellent XLR cable.
The quality of the cable is outstanding.
A must if you want to have a stack of hi-fi components linked via XLR.
TUTTO PERFETTO!
Spedizione veloce e accurata.
Tutto perfetto!
Grazie.
Excellent câble XLR !
Ce câble fait preuve d’une grande qualité de fabrication ce qui laisse présager une grande robustesse. Il est cependant très rigide ce qui avec sa faible longueur ne permet de relier que deux appareils qui se touchent. Associé aux appareils de la même marque, il faut bien les mettre en forme sinon ils sont capables de les soulever ! Ainsi, il faut que l’appareil soit suffisamment lourd pour bien rester en place. Voilà pourquoi, si je devais refaire cet achat, je prendrais le même câble mais dans une plus grande longueur pour éviter ce problème et surtout pouvoir placer les appareils plus librement en cas de changement de configuration. Bref, je recommande pour la qualité malgré ce petit désagrément lié à l’installation.
Une rolls
Cable de super facture, robuste et de qualité.
Une Rolls.
TCX1 cables from Topping are high quality XLR male/female cables. They incorporate 6N Copper and Silver plated 6N Copper conductors for perfect...
