Acrylic Case KIT for Raspberry Pi 3 / Pi 2 and Digipi+ (Digital interface)
3.5 / 5
Reference : 11742
3,90 €tax incl.
3,25 € tax excl.
This acrylic case kit has been designed to offer the Raspberry Pi + Audiophonics Digipi + bundle a cover and protection against possible shocks and external pollution.
Its durable acrylic design will protect your Raspberrry Pi and your Digipi + for a long time. All the necessary openings are available to take full advantage of your system: 4x USB,href = "http://www.audiophonics.com/en/cables-ethernet-rj45-c-602.html" target = "_ blank">Ethernet, 3.5mm Jack, HDMI, Micro USB, Micro SD card slot, Optical, Coaxial, etc ...
Features:/ Strong>
  • Kit acrylic case: to mount yourself
  • All necessary openings for the Raspberry Pi are provided
  • All necessary openings for the Digipi + are provided
  • Mounting screws provided with housing
  • Case delivered naked without Raspberry Pi 3 / Raspberry Pi 2 / Audiophonics Digipi +
Dimensions / Weight:
  • Dimensions: 97x77x39mm
  • Net Weight: 85g
  • Black color
- compatible with the microSD card doubler (not included) -
- Illustration with a Raspberry Pi 3 and audiophonics digipi + (not included) -
Color
  • Black
Material
  • Acrylic
2 reviews
Fait le job pour pas cher
Montage un peu long (surtout le temps de décoller toutes les protections des plaques)
Le montage se fait sans problème. Commencer par monter le digipi sur le raspberry
Seul bémol, la sortie optique est difficilement utilisble, perso je passe en spdif donc pas de souci)
Bref boitier correct pour le prix
This review has been posted for Acrylic Case KIT for Raspberry Pi 3 / Pi 2 and Digipi+ (Digital interface)
Boitier utilisé pour protéger l'interface digitale et le RaspBerry, obligé d’agrandir le trou pour le passage du connecteur coaxial. Ne pas trop serrer les vis qui referment le boitier grâce aux entretoises ..... trop tard, deux pattes cassées ...! Qualité médiocre mais normal vu le prix.
