ALLO Acrylic Case for Allo DigiOne and Raspberry Pi 3 Black
4.2 / 5
Reference : 12079
14,90 €tax incl.
12,42 € tax excl.
ALLO DigiOne + RPI Case
- Black Acrylic Case for Digione and Raspberry Pi -
Case for Allo Digione and Raspberry Pi
PROTECTION & DESIGN
This case was specially designed to accommodate the duo Raspberry Pi and Allo DigiOne . In black acrylic, the case will protect your system from dust and shock, while giving it a modern design that will showcase it. An indispensable one for the holders of the system.
Please note:Raspberry Pi and the DigiOne Allo are not included. This is the case only.
TECHNICAL CHARACTERISTICS
  • Material: Acrylic
  • Case color: Black
  • Color spacers: Black
  • Supplied with all screws (screws + spacers) required
  • Compatibility: Allo DigiOne and Raspberry Pi
Boîtier pour Allo Digione et Raspberry Pi
Color
  • Black
Material
  • Acrylic
6 reviews
ALLO boitier pour DigiOne et Pi 3
Le rapport qualité / prix est très bien.
Je suis pas très bon bricoleur, mais sur Internet on peut trouver des video de montage ... bref, montage facile et clair.
Seul petit regret : non transparent : suivi visuel des leds impossible.
This review has been posted for ALLO Acrylic Case for Allo DigiOne and Raspberry Pi 3 Black
Looks nice, does its job well
The case looks good, although it is not transparent as in the images (solid black).
A little work to get the protective paper layer off, but some hot water and it peels off pretty easily.
Assembly is a breeze, but make sure to place remove the screw ring on the DigiOne coax connector before adding the sidepanel, or it wont fit correctly.
Not as described
The only reason I bought an Allo Digione board for Rpi at Audiophonics and not some other supplier was because Audiophonics also sells this case. I think the see through acryl looks awesome. So I was pretty dissapointed when I opened the package and the case was not seethrough acryl with a dark shine, but just plain old black. BLACK, totally black, no see through whatsoever. If I had known this I would have looked elsewhere. So only 2 stars just because it's a case, but i'm pretty dissapointed with Audiophonics for selling a product that realy differs from the picture advertised above...
Practical case, almost as described
The characteristics and dimensions of the case is as described. It has anything you might need for assembling a pi2/3 with a digione, even screws and spacers provided also by digione. The assembly is easy and intuitive. However, in my case it was not a black acrylic but a light brown cardboard. I'm OK with that, I would order it in any case, but for this difference in description I can't give the fifth star.
Good case, hard to assemble
Good case, sturdy and looks great. Only thing, it is a pain to assemble, took me 1 hour, not very intuitive. But once assembled, everything perfect.
