ALLO Aluminum Case for Allo DigiOne Player + Raspberry Pi 3 Black
Reference : 13253
59,90 €tax incl.
49,92 € tax excl.
Aluminum Housing for ALLO Digione player
Housing only
This 100% aluminum casing is designed to dress up and protect your ALLO Digione player.
Its construction entirely aluminum protects yout device from electronic interference and noise while providing good heat dissipation.
In the same way, the middle segment has a heatsink for passive cooling: it reduces from 15 to 30% the processor core temperature, which is a significant improvement in terms of reduction of distortion and enhancement of audio performance.
This accessory comes with floating stands that can be mounted on silicone. Those stands contribute to reduce hardware vibration.
Mounting video
The case is supplied alone. The Raspberry Pi and the DigiOne are sold separately.
This product is only compatible with the Raspberry Pi 3. It is not compatible with Raspberry Pi 4.
TypeHousing
MaterialAluminum (AL6061)
InstallationA self-assembly
Number of elements to assemblex3
passive coolingYes
Anti-vibrations standsYes
3 reviews
Great little enclosure
Am very satisfied with this purchase. Nice design and well built. Changes the looks from the previous "cheap" plastic housing. Parts are well machined and everything fits in perfectly. Well worth the money
This review has been posted for ALLO Aluminum Case for Allo DigiOne Player + Raspberry Pi 3 Black
Supprime les interférences
Avec le boitier en acrylique je ne passais pas plus d'une journée sans que Volumio plante à cause des interférences.
Depuis l'installation du boitier en aluminium cela fait 7 jours que Volumio fonctionne sans avoir à le rebooter.
A confirmer par d'autres utilisateurs.
Excelent boots.
The little rubber feet have tot be glued. If the design would be a Little different this would not be necessary. Greater feet or...
Not all micro USB connectors Will fit, There is not much space due to the ( Nice) foot of the box.
