SUPTRONICS Aluminium Case and Accessories for X400 Module and Raspberry Pi
This box is intended to accommodate the DAC module / amplifier / headphone amplifier X400 as well as a Raspberry Pi. This one is made of robust Aluminium and has all the necessary holes to access all the connectors of the X400 and Raspberry Pi.
Reference : 13525
24,90 €tax incl.
20,75 € tax excl.
SUPTRONICS Case and accessories for X400
Boîtier Aluminium et Accessoires pour module X400 et Raspberry Pi
This box is intended to accommodate the DAC module / amplifier / headphone amplifier X400 as well as a Raspberry Pi. This one is made of robust Aluminium and has all the necessary holes to access all the connectors of the X400 and Raspberry Pi. There are also many holes in the housing to dissipate heat from the modules and prevent overheating.
The housing is delivered with an ON/OFF button, an Aluminium button for potentiometer and all the necessary screws for assembly.
The case is supplied alone. The Raspberry Pi and the X400 are sold separately.
This product is only compatible with the Raspberry Pi 3. It is not compatible with Raspberry Pi 4.
Product typeCase for X400 module
Case materialAluminium
Drill holes adapted to module X400 and Raspberry Pi-
Package1x Case for X400 + Raspberry Pi
1x Power ON/OFF button
1x Aluminium button for potentiometer
4x M2.5x28mm screws
6x M3x6mm screws
1x 1.5mm allen key
Color
  • Black
Material
  • Aluminium
This box is intended to accommodate the DAC module / amplifier / headphone amplifier X400 as well as a Raspberry Pi. This one is made of robust...
