Für mich eines derf besten Gehäuse für den Raspberry Pi!
This CNC machined aluminum case in KIT with an exemplary finish is the ideal transport tool for SBC Rapsberry Pi 2 and Pi 3. It can be integrated into a number of possibilities that simultaneously provide physical protection, heat sink, barrier against EMI waves in particular.
Its semi-perforated design allows the connection of all SBC Raspberry Pi connectors while protecting critical parts (chips, components). Thus the GPIO, the location for the camera connector and Micro SD CARD, the screen connector is fully accessible. The same is true for HDMI output, stereo out jack, 5V Micro USB connector, USB ports, RJ45 connector.
The accessible GPIO connector allows you to connect a DAC (Isabre V3, Allo Piano), digital audio output (DIGIPI +) or any Compliant HAT card.
The smoked acrylic plate on the front allows the transmission of WIFI and Bluetooth waves and the reading of the two control LEDs.
Supplied with a hexagon wrench, it allows a wide range of applications for a Raspberry PI: internal shielding, transport, Hifi-DIY, installation in a server, integration CAR audio and multiroom home automation.
Two squares of pasta thermsupplied on the Broadcom SOC of the Pi 2 or Pi 3 as well as on the Elipda chips (below the PCB). Thus,strong>this housing also serves as a heat sink.
Raspberry Pi 3 and accessories DAC ALLO Piano, KAli, I-SABRE V3, 40-pin tablecloths sold separately.br>
The KIT contains:
Dimensions and weight:
Average votes 5.0 / 5 1 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
