Cache bien fini et pratique pour cacher carte son et autres éléments de mon raspberry.
- Cover for SmartiPi / Large (37mm) -
Already excellent, the SmartiPi Touch can now be accompanied by a resistant ABS plastic back cover. It will protect your components attached to the back of the SmartiPi from shocks, dust and its environment, but it will also give a more certain design in order to conceal the components without obstructing the access to Raspberry Pi connectors.
Depending on your uses, you can then simply drill and cut to the required locations, in order to obtain a cache that exactly meets your needs.
This is theodèle Large, with a depth of 37mm. If this is too deep for your use, a Small version of 15mm is available by following this link.
Warning: This product only corresponds to the back cover. It is therefore delivered without the SmartiPi, the screen or the Raspberry.
Average votes 5.0 / 5 3 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
JEAN-LUC L.
Christophe P.
Jonathan Z.
