Support Raspberry Pi 4 / 3 / 2 pour écran tactile officiel
The SmartiPi Touch Pro is a case for the official display of the Raspberry Pi 2, 3 and 4. Thus, with the SmartiPi Touch Pro you can create an all-in-one Raspberry Pi system with a single USB-C port to power all components. The Raspberry Pi is mounted behind the screen and its connectors remain accessible on the side of the case, with covers to hide unused connectors. A second set of inserts with screw threads allows you to mount your own development board or any other component.
A slot behind the screen also allows to mount the Raspberry Pi V1 or V2 camera (not compatible with Raspberry Pi HQ Camera). The location of the camera can be hidden with the adhesive panel provided.
The housing is made of molded ABS plastic and can therefore be easily drilled for total customization.
Product type | Raspberry Pi and touchscreen stand |
Material | ABS |
Pivot angle | 37° |
VESA Support | 75mm |
Package | SmartiPi Touch Pro Large Micro USB Splitter USB-C Splitter Fan |
