SHANLING CD80 CD Player Philips Sanyo HD860 DAC ES9219MQ Bluetooth 5.0 LDAC Silver
The Shanling CD80 is an efficient CD player with integrated DAC. It performs these functions brilliantly, thanks to its meticulous architecture and high-quality components, enabling it to offer superb playback and decoding quality, so you can enjoy your CDs to the full.
By buying this product you get 35 loyalty points
Reference : 18276
359,00 €tax incl.
299,17 € tax excl.
Last items in stock !
Shipping date: 22-04-2025.
Shanling CD80
SHANLING CD80 CD Player Philips Sanyo HD860 DAC ES9219MQ Bluetooth 5.0 LDAC Black
Philips CD Player & USB input
The CD80's front panel features a Philips CD player with Sanyo HD860 laser technology, ensuring optimum playback of your audio CDs. Playback quality is enhanced by the integration of an Ingenic X1000 microprocessor, providing the player with significant data processing power.
The CD80 also features a USB input. This allows playback of high-resolution audio files up to PCM 32bit 384kHz and DSD256.
ES9219MQ DAC
The CD80's digital-to-analog conversion section uses an ESS Sabre ES9219MQ DAC for first-rate decoding. This configuration offers both clarity and power for an optimal musical experience. This chip also supports high sampling rates, up to PCM 32bit 384kHz and DSD256. What's more, it is capable of decoding MQA streams, guaranteeing sound quality as close as possible to studio recording.
Bluetooth 5.0
With its Bluetooth 5.0 module, the Shanling CD80 is able to receive audio streams wirelessly, from a smartphone or tablet for example, for practical, intuitive use. It also supports the high-resolution LDAC audio codec, ensuring high-quality wireless transmission and playback.
Simple, efficient connectors
The Shanling CD80 offers simple connectivity. There's a USB-A input for file playback, and Toslink optical and RCA stereo outputs. The front panel also features an amplified headphone output in 3.5mm jack format.
Eddict Player app
The CD80 can be controlled remotely via its remote control or the free Eddict Player mobile app, available for both Android and iOS. In addition to managing playback, the latter offers access to the device's various functions.
1CD Player
2Volume display
3IR receiver
4Display
5USB port
6Previous track
7Play / Pause
8Next track
9Stop / Eject
10Volume
11Power ON/OFF / Input selection button
12Status indicator
13Jack 3.5mm headphone output
Shanling CA80 Amplificateur Class D Lecteur CD DAC ES9219MQ Bluetooth 5.0 100W 4 Ohm Noir
1Power button
2Power input
3RCA output
4Optical output
5Bluetooth antenna
Technical charateristics
Product typeCD player
DAC
DAC chipES9219MQ
MicroprocessorX1000
Control appEddict Player
Headphone output power130mW @ 32 Ohm
Frequency response (headphone output)20Hz-40kHz (-0.2dB)
THD+N (headphone output)0.0015%
Channel separation (headphone output)75dB @ 32 Ohm
Dynamic range (headphone output)119dB
SNR (headphone output)118dB
Output impedance (headphone output)< 1 Ohm
Output level (line out)2Vrms
Frequency response (line out)20Hz-40kHz (-0.2dB)
THD+N (line out)0.008%
Channel separation (line out)110dB
SNR (line out)116dB
InputsCD
Bluetooth
1* USB-A
Outputs1* Optical Toslink
1* Jack 3.5mm headphone output
1* RCA
Supported Bluetooth codecsSBC, AAC, LDAC
DSD up to DSD256
MQA
Supply voltage100-240VAC
Consumption20W
Dimensions250*205*52mm
Weight2.4kg
ColorSilver
Définition et précision pour pas cher.
Je viens de m'offrir ce joli lecteur cd en remplacement de mon bon vieux Rega Planet.Le Shanling est moins encombrant et plus pratique (chargement du disque frontal un peu bruyant cependant....).
La musique qui en sort m'enchante.C'est précis et définit sans être froid. Je découvre de petits signaux musicaux que le Réga occultait.Bref,je suis heureux de mon joujou,Ma seule critique ira vers ces petits "clics" électrique que j'entends à chaque changement de piste du disc ,ainsi qu'au démarrage et fin de lecture.(en manuel ou avec la télécommande)
Le Bluetooth fonctionne aussi très bien.
Merci à Audiophonics qui a assuré pour le délai de livraison.C'est bon de pouvoir compter sur autant de sérieux.
This review has been posted for SHANLING CD80 CD Player Philips Sanyo HD860 DAC ES9219MQ Bluetooth 5.0 LDAC Silver
The Shanling CD80 is an efficient CD player with integrated DAC. It performs these functions brilliantly, thanks to its meticulous architecture and...
