as one of the previous reviewers said, this is a very good transport. The only disadvantage is you cannot select the track number
By buying this product you get 22 loyalty points
CD Player and USB Flash Drive File Reader Black
The Shanling Tempo eC1B CD player is based on a PCM1796 decoding chip and two NE5532P operational amplifiers, providing a rich musicality. The AOPs are mounted on a DIP8 bracket. The CD player features an extremely reliable Sanyo HD850 mechanism, ensuring flawless track tracking. The eCB1 Tempo also allows you to read dematerialized files stored on a USB stick or hard disk, thanks to its USB-A port on the front panel. It can also be used as a drive thanks to its Coaxial SPDIF output.
1 | Power ON/OFF LED |
2 | Power ON/OFF button |
3 | CD player tray |
4 | Display |
5 | IR receiver |
6 | Multi-directionnal button |
7 | USB-A Input |
1 | Stereo RCA Output |
2 | SPDIF Coaxial Output |
3 | AC Power supply input |
Product type | CD Player |
Inputs | 1x CD 1x USB-A |
Outputs | 1x Stereo RCA 1x Coaxial SPDIF |
Conversion chip | PCM1796 |
AOP | 2x NE5532P |
CD Mechanic | Sanyo HD850 |
Line output level | 2V |
Frequency response | 20Hz - 20kHz |
Dynamic range | 96dB |
SNR | 105dB |
THD | < 0.002% (1kHz) |
Crosstalk | > 96dB |
Supported dematerialized files | WAV, AAC, WMA, MP3 |
Sampling rate | 16bit 44kHz |
Consumption | < 20W |
Dimensions | 216 x 312 x 71mm |
Weight | 3kg |
Power supply | 250V AC (cable included) |
Color | Black |
Package | 1x Shanling Tempo eCB1 Black 1x IR Remote control (CR2032 battery included) 1x Power cable |
Average votes 4.5 / 5 22 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Christopher G.
Jean-François C.
Noel C.
Philippe D.
Bart d.
