CD Player AD1955 DAC
The Tonewinner TY-30 is a beautifully integrated CD player, based on the use of quality components for efficient CD playback. The chassis is perfectly damped in order to limit considerably the vibrations that could affect the playback and its stability.
The digital/analog conversion section of the TY-30 uses an Analog Devices AD1955 chip supporting PCM up to 24bit 192kHz and ensuring a distortion level lower than -110dB. This chip contributes to give this CD player a precise and transparent sound.
The on-board CD player benefits from a design optimized by the brand, allowing for highly efficient playback. It is physically isolated from other circuits to limit interference and rests on an anti-vibration base for optimal stability.
The Tonewinner TY-30 has a classic and sober design. It will therefore fit easily into a HiFi cabinet without standing out from the rest of the system. The chassis has a thick brushed aluminum front panel that looks great. It is also mounted on effective anti-vibration feet.
1 | Optical Toslink input |
2 | Coaxial input |
3 | RCA output |
4 | XLR output |
5 | RCA output |
6 | Coaxial output |
7 | Optical Toslink output |
8 | Input voltage selector |
9 | Power input |
Product type | CD Player |
Inputs | 1* Coaxial 1* Optical Toslink |
Outputs | 1* Coaxial 1* Optical Toslink 2* Stereo RCA 1* Stereo XLR |
DAC chip | AD1955 |
Output voltage | 2V ±1dB (1kHz) |
Crosstalk | ≥ 104dB (1kHz) |
Frequency response | 20Hz~20kHz (+0/-1dB) |
THD | ≤ 0.005% (1kHz) |
Supply voltage | 110-230VAC 50/60Hz (switchable) |
Dimensions (L*P*H) | 444*370*106mm |
Weight | 8.3kg |
Color | Black and silver |
Package | 1* Tonewinner TY-30 1* Remote control (CR2025 battery not included) 1* Power cable |
