The SMSL PL100 CD player is the perfect way to enjoy your CD collection. It's essentially based on a CS43131 DAC chip and a PLL (Phase-Locked Loop) circuit for sound reproduction as close as possible to the original source. Various CD formats are supported: CD / CD-R / CD-RW / MP3 CD. Several outputs are also available, including a coaxial output, a Toslink optical output and an analog RCA output. There's an additional 3.5mm jack headphone output capable of delivering up to 2x60mW under 32 Ohm. The user experience is enhanced by the small display on the PL100's front panel, as well as the various control buttons and remote control.
The CS43131 DAC chip, coupled with the PLL circuit, offers high-quality CD decoding for high-quality final sound reproduction. The PLL circuit greatly reduces jitter during playback.
The PL100's SPDIF Coaxial and Toslink optical outputs are capable of outputting the raw signal for direct connection to a DAC, so you can enjoy the best possible sound.
Thanks to its CS43131 DAC chip, the SMSL PL100 CD player is also able to deliver up to 60mw under 32 ohms of power on its 3.5mm jack output to drive a wide range of headphones and IEMs.
The form factor of the SMSL PL100 CD player allows it to be positioned either horizontally or vertically.
1 | Coaxial output |
2 | Toslink optical output |
3 | 3.5mm headphone output |
4 | RCA output |
5 | 5V 2A USB power input |
This device does not work with USB-PD (Power Delivery) power supplies.
Product type | CD player |
DAC chip | CS43131 |
Input | CD |
Outputs | 1x Coaxial 1x Toslink optical 1x RCA output 1x Jack 3.5mm headphone output |
Supported CD formats | CD / CD-R / CR-RW / CD MP3 |
Headphone output power | 60mW @ 32 ohm |
THD+N | 0.001% |
SNR | 110dB |
Power supply | 5V 2A via USB |
Power consumption | 4W Standby: < 0.1W |
Dimensions | 160 x 162 x 42mm |
Weight | 1.2kg |
Color | Black |
Package | 1x SMSL PL100 CD player 1x Power supply USB cable 1x Remote control |
