SMSL PL100 CD Player CS43131 Silver
The SMSL PL100 CD player is the perfect way to enjoy your CD collection. It's essentially based on a CS43131 DAC chip and a PLL (Phase-locked Loop) circuit for sound reproduction as close as possible to the original source.
Reference : 20392
119,90 €tax incl.
99,92 € tax excl.
SMSL PL100 picture
The SMSL PL100 CD player is the perfect way to enjoy your CD collection. It's essentially based on a CS43131 DAC chip and a PLL (Phase-Locked Loop) circuit for sound reproduction as close as possible to the original source. Various CD formats are supported: CD / CD-R / CD-RW / MP3 CD. Several outputs are also available, including a coaxial output, a Toslink optical output and an analog RCA output. There's an additional 3.5mm jack headphone output capable of delivering up to 2x60mW under 32 Ohm. The user experience is enhanced by the small display on the PL100's front panel, as well as the various control buttons and remote control.
SMSL PL100: CS43131 DAC chip
The CS43131 DAC chip, coupled with the PLL circuit, offers high-quality CD decoding for high-quality final sound reproduction. The PLL circuit greatly reduces jitter during playback.
DAC chip CS43131
Raw digital outputs
SMSL PL100: Raw digital outputs
The PL100's SPDIF Coaxial and Toslink optical outputs are capable of outputting the raw signal for direct connection to a DAC, so you can enjoy the best possible sound.
SMSL PL100: Headphone output
Thanks to its CS43131 DAC chip, the SMSL PL100 CD player is also able to deliver up to 60mw under 32 ohms of power on its 3.5mm jack output to drive a wide range of headphones and IEMs.
3.5mm headphone output
A practical form factor
SMSL PL100: Two installation options
The form factor of the SMSL PL100 CD player allows it to be positioned either horizontally or vertically.
SMSL PL100 overview
SMSL PL100 overview
1Coaxial output
2Toslink optical output
33.5mm jack headphone output
4RCA output
55V 2A USB power input
This device does not work with USB-PD (Power Delivery) power supplies.
Product typeCD player
DAC chipCS43131
InputCD
Outputs1x Coaxial
1x Toslink Optical
1x RCA output
1x 3.5mm jack headphone output
Supported CD formatsCD / CD-R / CR-RW / CD MP3
Headphone output power60mW @ 32 Ohm
THD+N0.001%
SNR110dB
Power supply5V 2A via USB
Power consumption4W
Standby: < 0.1W
Dimensions160 x 162 x 42mm
Weight1.2kg
ColorSilver
Package1x SMSL PL100 CD player
1x Power supply USB cable
1x Remote control
2 reviews
Excellent!
Great little CD player!
Very nice looks, decent remote control and superb sound quality! I first tried it with the optical out into my Aune X8 DAC with Sparcos Op-Amp. Sounded great.
After that I decided to try the onboard DAC and it sounds almost as good as my external DAC, that costs 4 times the whole CD player!
Overall, I am very pleased with it!
This review has been posted for SMSL PL100 CD Player CS43131 Silver
RQP exceptionnel
Je n’en reviens pas encore. Je l’utilise en drive avec la sortie optique vers un WIIM AMP PRO. Le rendu est précis et légèrement chaud, très agréable. La mécanique d’origine Philips semble-t-il est douce et ultra silencieuse quelque soit la qualité du CD.
Je n’ai pas encore testé la sortie analogique car ce n’était pas le but de cet achat pour moi mais quand ce sera fait je posterai à nouveau un avis.
A ce prix franchement, difficile de faire mieux.
The SMSL PL100 CD player is the perfect way to enjoy your CD collection. It's essentially based on a CS43131 DAC chip and a PLL (Phase-locked...
