FIIO DM13 BT CD Player Ripper Black
FiiO's DM13 BT is a portable CD player with a sleek design and undeniable internal component quality. Its aluminum body houses two DAC chips from Cirrus Logic to offer a conversion of your favorite CDs as close to the original as possible. The 660mW + 660mW amplification at 32Ω provided by the balanced outputs means you can easily connect any headphones or amplifier, furthermore the digital output means you can integrate it into a complete HiFi system by delegating the conversion of your CD signal to an external DAC.
Reference : 20263
149,00 €tax incl.
124,17 € tax excl.
Shipping date: 22-04-2025.
FiiO DM13 BT CD Ripper Player on Battery 2xCS43198 Black
FiiO DM13 : 3/4 view
FiiO's DM13
is a portable CD player with a sleek design and undeniable internal component quality. Its aluminum body houses two DAC chips from Cirrus Logic to offer a conversion of your favorite CDs as close to the original as possible. The 660mW + 660mW amplification at 32Ω provided by the balanced outputs means you can easily connect any headphones or amplifier, furthermore the digital output means you can integrate it into a complete HiFi system by delegating the conversion of your CD signal to an external DAC. Furthermore, the BT version of this CD player features Bluetooth connectivity supporting high-resolution codecs, so you can enjoy CD quality wirelessly.
FiiO DM13: Cirrus Logic CS43198 DAC
For optimized digital/analog conversion, the DM13 deploys two Cirrus Logic CS43198 DAC chips, offering the dual benefits of reduced power consumption and excellent audio quality. This chip also features 99 levels of volume control, for smooth, precise adjustment while maintaining crystal-clear sound reproduction.
FiiO DM13 : CS43198 chip
FiiO DM13 : CD player with headphones
FiiO DM13: SGM8262 amplification chip
The DM13's amplification stage is handled by two SGM8262 chips, providing output power of 660mW + 660mW at 32Ω balanced and 180mW + 180mW at 32Ω single-ended. This power allows even the most demanding headphones to be driven efficiently, without any worries.
FiiO DM13: Portable CD player
The DM13 has been designed first and foremost as a portable CD player. Its appearance is the fruit of FiiO's efforts to make it as compact as possible without neglecting its technical capabilities. This CD player can follow you anywhere, and is equipped with a 3750mAh cobalt-lithium battery for up to 10 hours of uninterrupted playback.
FiiO DM13 : battery capacity
FiiO DM13 : Screen view
FiiO DM13: LCD display
The DM13 boasts a high-contrast LCD display that shows information such as volume, track number and duration, so you always know exactly where you stand.
FiiO DM13: Complete connectivity
The DM13 has two headphone jack outputs, one 4.4mm balanced, the other 3.5mm single-ended, as well as two line outputs for connection to a power amplifier or active speakers. Furthermore, this CD player also benefits from a coaxial/optical output to provide a DAC with a stable signal, thanks to its low-jitter internal clock.
FiiO DM13 : Connectors
FiiO DM13 : Computer-connected player
FiiO DM13: Ripper function
The DM13 also lets you rip your CDs in WAV format, so you can easily share your music with friends, or more simply, let your music follow you wherever you go on your phone or computer.
FiiO DM13 BT: Bluetooth function
The BT version of the DM13 also benefits from a Qualcomm Bluetooth chip, so you can enjoy it with headphones or wireless earphones. This enables this CD player to support high-definition audio codecs such as aptX, aptX Low Latency and aptX HD, in addition to more traditional codecs such as SBC, ensuring that CD quality is maintained, even over a wireless connection.
FiiO DM13 BT : CD player with wireless earphones
FiiO DM13 BT : USB-powered drive
FiiO DM13 BT: Desktop mode
Moreover, as a portable device, the DM13 can also be used powered by its USB-C port rather than by battery, simply by activating the Desktop mode via the switch on the side of the device, thus allowing you to use it without wearing out the battery in the slightest.
FiiO DM13 BT: Advanced functions
When designing its CD player, FiiO gathered extensive feedback from users in order to integrate useful functions. For example, you can now mark as favorite certain tracks on your CDs, as well as activate loop playback or remove silences between two tracks.
FiiO DM13 BT
Product typeCD player
Ripper
Outputs1x Balanced 4.4mm jack headphone output
1x Single-ended 3.5mm jack headphone output
1x Balanced 4.4mm line output jack
1x Single-ended 3.5mm line output jack
1x Coaxial / Optical output
ScreenLCD 1.5"
DAC chips2x CS43198
Amplification chips2x SGM8262
Adaptive impedanceSingle-ended: 8~150Ω
Balanced: 8~350Ω
Battery autonomy10h
Battery charge time2.5h
Supported Bluetooth codecsSBC, aptX, aptX Low Latency, aptX HD
Gapless playback
Headphone output specifications
Output power 4.4mm jack620mW+620mW (16Ω, THD+N<1%)
660mW+660mW (32Ω, THD+N<1%)
80mW+80mW (300Ω, THD+N<1%)
Output power 3.5mm jack270mW+270mW (16Ω, THD+N<1%)
180mW+180mW (32Ω, THD+N<1%)
20mW+20mW (300Ω, THD+N<1%)
CrosstalkBalanced: 120dB
Single-ended: 77dB
Frequency response20Hz-20kHz (-2.3dB)
Output impedanceBalanced: 1.5Ω
Single-ended: 1Ω
Total harmonic distortion more noise (THD+N)Balanced: 0.0024%
Single-ended: 0.0025%
Signal-to-noise ratio (SNR)Balanced: 124dB
Single-ended: 120dB
Noise floorBalanced: 2.8μV
Single-ended: 2.4μV
Peak output voltageBalanced: 14 Vp-p
Single-ended: 7Vp-p
Line output specifications
CrosstalkBalanced: 106dB
Single-ended: 105dB
Total harmonic distortion more noise (THD+N)Balanced: 0.0022% (1kHz/0dB@10kΩ)
Single-ended: 0.0026% (1kHz/0dB@10kΩ)
Single-ended: 113dB
Noise floorBalanced: 3μV
Single-ended: 4.3μV
Output levelBalanced: 5V
Single-ended: 2.5V
Power supply5V DC 2A
Weight450g
Dimensions137 x 144 x 28mm
Package1x FiiO DM13 BT
1x USB-A to USB-C cable
Jack 3.5mm to coaxial adapter
Download
FIIO DM13 BT CD Player Ripper on Battery 2xCS43198 Black
FiiO's DM13 BT is a portable CD player with a sleek design and undeniable internal component quality. Its aluminum body houses two DAC chips...
