ORIGINAL AUDIO CD-V5 CD Player PCM1795 GE5670 Tubes 32bit 192kHz
The Original Audio CD-V5 is firstly noticed by its modern and pure design, with assertive lines. This aesthetic is complemented by excellent performance with an SNR and a dynamic range measured at 100dB as well as a THD of only 0.0025%. To achieve this, the CD-V5 uses quality components, including five OPA2134 PDUs and a digital-to-analog conversion stage based on a PCM1795 DAC chip.
By buying this product you get 104 loyalty points
Reference : 16336
1 049,00 €tax incl.
874,17 € tax excl.
Original Audio CD-V5 Lecteur CD PCM1795 Tubes GE5670 32bit 192kHz
The Original Audio CD-V5 is firstly noticed by its modern and pure design, with assertive lines. This aesthetic is complemented by excellent performance with an SNR and a dynamic range measured at 100dB as well as a THD of only 0.0025%. To achieve this, the CD-V5 uses quality components, including five OPA2134 PDUs and a digital-to-analog conversion stage based on a PCM1795 DAC chip. Of singular design, the analog RCA output stage is amplified by a pair of GE5670 tubes. The power supply stage embeds two toroidal transformers with shields, ensuring a clean and stable electrical signal, effectively limiting interference.
In addition to CD playback, the CD-V5 provides a USB-B audio input, supporting sample rates up to PCM 32bit 192kHz. On the output side, there are Toslink optical and coaxial outputs, as well as a single-ended RCA output and a balanced XLR output.
Product typeCD Player
InputsCD
1x USB-B
Outputs1x Balanced stereo XLR
1x Single-ended stereo RCA
1x Optical Toslink
1x Coaxial
DAC ChipPCM1795
Supported sampling ratesPCM up to 192kHz
OPA5x OPA2134
Tubes (RCA analog output)2x GE5670
Frequency response20Hz-20kHz, 2dB
SNR100dB
Dynamic range100dB
THD0.0025%
Output level2Vp-p
Supply voltage220VAC 50Hz
Dimensions430 x 330 x 80mm
Weight8.5kg
Operating temperature+5°C / +35°C
Un excellent lecteur CD, une belle surprise
Je n’avais pas écouté de son tube sur ce type de source, ce lecteur d’une marque confidentielle chinoise a un son captivant sur les voix, c’est ce que j’écoute en grande majorité. Le son n’est pas trop épais ou « pâteux », son son n'a qu'une légère chaleur, pas de coloration chaude trop évidente ni trop forte, et la transparence du son est bonne, on a une restitution douce et fluide. J’avais auparavant un lecteur Denon 2500 NE qui utilisait le même DAC (pas de tubes), ce lecteur Original s’avère d’un niveau comparable avec davantage d’opulence dans les timbres et de douceur. Le Denon coûtait plus de deux fois le prix de celui-ci. La section numérique (coaxial testé) est de bonne qualité, j’ai testé avec mon Gustard R26 , cela donne un son plus dynamique, avec plus d’espace, de largeur. Je considérerai que ce lecteur avec son DAC propre correspond à un appareil de la gamme moyenne supérieure, avec la sortie coaxiale avec un DAC plus performant on a un son plein et équilibré. Donc ce lecteur très bien fini, de construction solide constitue une offre très intéressante en termes de prix, son DAC peut en outre être exploité. Le chargement par le dessus avec un palet presseur se voit sur des appareils haut de gamme en général. Reste à voir la fiabilité (point faible des lecteurs CD au niveau du mécanisme de lecture, ici c’est du Sony), l’avenir le dira, je dirais à conseiller pour ceux qui recherchent la musicalité avant tout sans dépenser une fortune, les mesures de l’appareil sont bonnes sans plus, ce n’est pas le lecteur CD qui vous donnera le plus de détails et d’amplitude au niveau de la dynamique, celle-ci est néanmoins suffisante. C’est rassurant de trouver de très bons lecteurs CD pour un budget acceptable, celui-ci en fait partie, j’envisageais un modèle britannique c’était deux fois et demi plus cher qui ressemble beaucoup à celui-ci, merci à Audiophonic de proposer des modèles de qualité avec un rapport prix / performance excellent.
This review has been posted for ORIGINAL AUDIO CD-V5 CD Player PCM1795 GE5670 Tubes 32bit 192kHz
The Original Audio CD-V5 is firstly noticed by its modern and pure design, with assertive lines. This aesthetic is complemented by excellent...
