SHANLING MCD1.3 CD Player Silver
Shanling's MCD 1.3 is a top-of-the-range CD player with an XMOS XU316 USB interface, AK4499EX+ AK4191EQ DAC chip combo, TPA6120 headphone amplification and MUSES8920 line-out pre-amplification. This device is extremely versatile, thanks in particular to its multiple connections coupled with Bluetooth 5.0 and WiFi functionality supporting DLNA and Airplay protocols and being able to be connected to a NAS.
By buying this product you get 101 loyalty points
Reference : 19370
1 019,00 €tax incl.
849,17 € tax excl.
Shipping date: 24-04-2025.
SHANLING MCD1.3 CD Player DAC AKM4499EX + AKM4191EQ Silver
SHANLING MCD1.3 : Front view
Shanling MCD 1.3 : Fast, high-performance CD player
The Shanling MCD 1.3 houses a high-performance dual-core Ingenic X2000 processor. This chip is the first based on XBurst2 technology, which not only improves computing power, but also enables the device to start up quickly. This processor is combined with a Philips SAA7824 decoder and a Sanyo DA11 playback head, offering excellent playback performance and high-quality sound reproduction.
Shanling MCD 1.3 : AKM AK4499EX+ AK4191EQ chips
The Shanling MCD 1.3 is equipped with the AKM AK4499EX (DAC) and AK4191EQ (digital filter) chip combo. This enables it to support high-resolution streams up to PCM 32bit 768kHz, native DSD up to DSD512 and MQA/MQA-CD, with a distortion rate of less than 0.0005% (-122dB).
SHANLING MCD1.3 : AKM AK4499EX+ AK4191EQ chips
SHANLING MCD1.3 : XMOS XU316 chip
Shanling MCD 1.3 : XMOS XU316 USB interface
The USB interface of Shanling MCD 1.3 is entrusted to an XMOS XU316 chip, providing transparent sound reproduction and support for high-resolution audio streams up to PCM 32bit 768kHz and DSD512.
Shanling MCD 1.3 : Flexible digital outputs
The Shanling MCD1.3 incorporates three digital outputs, allowing it to be paired with a higher-performance DAC if required. The I2S output via HDMI is optimised using an FPGA and is directly compatible with 10 different HDMI I2S pinouts. Optical and coaxial outputs are also available for easy connection to a DAC.
SHANLING MCD1.3 : I2S output pinout
Shanling MCD 1.3 : Pre-amplification according to outputs
The Shanling MCD1.3 also incorporates different pre-amplification stages depending on the output, allowing the most appropriate amplification of the signal in all circumstances. The line output is powered by two soft-sounding OPA MUSES8920s, while the headphone output is powered by a more powerful, harder-sounding OPA TPA6120, capable of driving the vast majority of headphones.
Product typeCD player
DAC
InputsCD/SACD
1x USB-B
1x Coaxial
1x Optical Toslink
1x USB-A (USB Host)
Bluetooth
Wi-Fi
Outputs1x RCA stereo
1x XLR balanced stereo
1x I2S via HDMI
1x Coaxial
1x Optical Toslink
1x Jack 6.35mm headphone output
DAC chipAKM AK4499EX + AK4191EQ
USB interfaceXMOS XU316
OPA2xMUSES8920
1xTPA6120
Supported Bluetooth codecsSBC, ACC, aptX, aptX HD, LDAC
Supported sampling ratesUSB : 32bit 768kHz DSD512
Coaxial and Optical : 24bit 192kHz
RCA OUTPUT MEASUREMENTs
Output level2.5Vrms
Frequency response20Hz-40kHz (-0.1dB)
Total harmonic distortion more noise (THD+N)0.0005%
Dynamic range119dB
Signal-to-noise ratio (SNR)119dB
XLR OUTPUT MEASUREMENTs
Output level5Vrms
Dynamic range122dB
Signal-to-noise ratio (SNR)122dB
6.35MM JACK HEADPHONE OUTPUT MEASUREMENTS
Output levelLow gain : 21.5mW @ 32Ω
Medium gain : 203mW @ 32Ω
High gain : 1120mW @ 32Ω
153mW @ 300Ω
Total harmonic distortion more noise (THD+N)0.001%
Channel separation75dB@32Ω
Dynamic range118dB
Signal-to-noise ratio (SNR)118dB
Output impedance4.7Ω
Dimensions280 x 280 x 96mm
Weight5.7kg
ColorSilver
Package1x Shanling MCD 1.3 CD Player DAC
1x Power cable
1x Remote Control
1x USB-A to USB-B cable 1.5m
InputCD
InputWiFi
OutputJack 6.35mm
OutputOptical Toslink
OutputI2S LVDS via HDMI
OutputCoaxial SPDIF
DAC / ADC ChipAK4499EX
Max sampling rateDSD512
Max sampling rateMQA
Max sampling rate768kHz
ColorSilver
NetworkingYes
Shanling's MCD 1.3 is a top-of-the-range CD player with an XMOS XU316 USB interface, AK4499EX+ AK4191EQ DAC chip combo, TPA6120 headphone...
