SHANLING CD-S100 (23) CD Player DAC AK4493 Sanyo HD850 USB 32bit 384kHz DSD512 Silver
The Shanling CD-S100 (23) is a high quality, high performance and versatile CD player. The core of the system is based on a triple-core Junzheng X2000 processor using XBurst2 architecture, ensuring high power for data processing. The digital-to-analog conversion stage uses a last version of AKM AK4493 chip, efficiently decoding the audio stream for accurate sound reproduction. The CD playback is done by a Philips CD80 servo system (MT1389L) and a Sanyo HD850 playback head.
By buying this product you get 59 loyalty points
Reference : 17603
599,00 €tax incl.
499,17 € tax excl.
Shipping date: 16-04-2025.
The CD-S100 (23) is also equipped with a Bluetooth 5.0 reception function thanks to the integration of an AP6256AC chip. This one thus allows a wireless audio transmission, from a smartphone for example, and is compatible with the LDAC high quality Bluetooth codec.
There is also an input USB-A port for reading files from a storage device, or a USB-B input, capable of reading high resolution streams up to PCM 32bit 768kHz and DSD512.
For its outputs, the CD-S100 (23) provides an analog output on stereo RCA, as well as two digital outputs, in optical and coaxial formats.
Finally, the front panel of the device features a nice round LCD display with a resolution of 320*290px, capable of displaying information about the current playback as well as the album covers.
Shanling CD-S100 (23) Lecteur CD DAC AK4493 Sanyo HD850 USB 32bit 384kHz DSD512
Updated servo system and new AOPs
With its new servo system (MT 1389L) philips CD80 and its Sanyo HD850 reading head, the reading system is very stable and reliable. In addition, the 23 version of the CD-S100 presents two new LTA 8092 AOPs. Overall, the performance of the CD-S100 improves with an SNR of 114dB, a dynamic range of 117dB and a distortion level falling below 0.0007 % .
SHANLING CD-S100 (23) Lecteur CD DAC AK4493 Sanyo HD850 USB 32bit 384kHz DSD512 Noir
Eddict Player App
If the Shanling CD-S100 (21) can be controlled in the traditional way thanks to the remote control supplied with the device, it can also be controlled using the free mobile application Edict Player. This application allows you to browse your music library and also to directly control the playback of your music.
Shanling CD-S100 (21) Lecteur CD DAC AK4493 Sanyo HD850 USB 32bit 384kHz DSD512
Product typeCD Player
InputsCD
Bluetooth 5.0
1x USB-B
1x USB-A Host
Outputs1x Stereo RCA
1x Optical Toslink
1x Coaxial
CPUJunzheng X2000 multicore
DAC ChipAKM AK4493
OPALTA 8092
USB InterfaceJunzheng X2000
ScreenAMLCD 320*290px
Control modeRemote control
App
Supported sampling ratesPCM up to 32bit 768kHz
DSD512
Supported file formatsDSD, DXD, APE, FLAC, ALAC, WAV, AIFF, AIF, DTS, MP3, WMA, AAC, OGG, MP3, M4A, AC30PUS, TAK, CUE
Output level2.1V
Frequency response20Hz-20kHZ ±1dB
SNR114dB
Distortion< 0.0007%
DNR117dB
Dimensions430 x 355 x 79mm
Weight≈ 6.6kg
ColorSilver
Package1x CD-S100 (23) Argent
1x Power cable
1x Remote control
The Shanling CD-S100 (23) is a high quality, high performance and versatile CD player. The core of the system is based on a  triple-core...
