SHANLING EC SMART CD Player
The Shanling EC Smart is an affordable, high-performance CD player with an atypical, resolutely modern design. With its vertical format, the EC Smart accommodates CDs just behind its control panel, which can be rotated. Everything is designed to be extremely easy to use, with no need for complicated settings or adjustments.
4.0 / 5
Reference : 19858
149,00 €tax incl.
124,17 € tax excl.
Shipping date: 22-04-2025.
Shanling EC Smart Lecteur CD Vertical Sanyo DA11 CS43131 Bluetooth 5.4
Shanling EC Smart CD player photo
At the heart of this design gem is a renowned optical drive, the Sanyo DA11. The audio circuit uses a Cirrus Logic CS43131 DAC capable of delivering precise, faithful sound reproduction.
Connectivity couldn't be simpler. The EC Smart can be used with either a pair of active speakers or an amplifier, thanks to its rear line output in 3.5mm jack format (RCA adapter supplied). The player also benefits from a dedicated headphone output on the side, also in 3.5mm jack format, associated with a headphone amplification stage carried by an SGM8262 chip.
The modern EC Smart also features Bluetooth 5.4 connectivity, so it can be paired with Bluetooth speakers for convenient wireless installation.
Thanks to its compact design and predominantly aluminum construction, the EC Smart fits easily into most interiors. What's more, although it's designed to be used mainly vertically, the bottom bracket can be removed, and the CD player can simply rest on its rear rubber feet, for horizontal installation.
When it comes to power, the Shanling EC Smart aims for even greater ease of use, since it requires only a standard 5V USB power supply and can therefore be powered by any phone charger, by the USB port on a computer or certain televisions, and even with a suitable portable battery.
Control of the unit is via the front control panel, featuring touch-sensitive buttons, or via the supplied infrared remote control.
Product typeCD Player
Outputs1x Jack 3.5mm line output
1x Jack 3.5mm headphone output
Bluetooth
Optical driveSanyo DA11
DAC chipCS43131
Headphone amp chipSGM8262
Headphone output power180mW @ 32Ω
THD+N0.001%
Channel separationHeadphone output: 75dB
Line out: 110dB
Dynamic rangeHeadphone output: 120dB
Line out: 122dB
SNRHeadphone output: 120dB
Line out: 122dB
Output impedance (headphone output)< 1Ω
Output level (line output)2.4Vrms
DisplayDot matrix
Power supply5V DC 2A via USB-C (power adapter sold separately)
ColorWhite
Housing materialAluminum stand and body
Plastic rear panel
Dimensions (with stand)208 x 109 x 75mm
Weight586g
Package1x Shanling EC Smart
1x IR remote control
1x Jack 3.5mm to RCA adapter
1x USB-A to USB-C cable
Elégant lecteur et pratique
Peut se mettre à la verticale ou à l'horizontal. La dynamique est bonne.
Le son délivré par le jack casque et par le BT a de la puissance.
Quand utilisé à plat, les entrées arrières / dessous, ne sont pas très pratiques.
This review has been posted for SHANLING EC SMART Lecteur CD Vertical Sanyo DA11 CS43131 Bluetooth 5.4
The Shanling EC Smart is an affordable, high-performance CD player with an atypical, resolutely modern design. With its vertical format, the EC...
