SMSL VMV T2 CD Player
The SMSL VMV T2 is part of the brand's high-end product range. It's an MQA CD player that also acts as a digital interface, and features an optimized clock system. It is equipped with a P.A.S.S (Precison Access Servo System) playback system that natively supports MQA-CD. The SMSL VMV T2 also supports high-resolution PCM 32bit 768kHz and DSD512 streams, as well as full MQA decoding on some of its digital inputs.
By buying this product you get 94 loyalty points
Reference : 19478
949,00 €tax incl.
790,83 € tax excl.
SMSL VMV T2 CD Player MQA Bluetooth 5.1 AptX HD LDAC 32bit 768kHz DSD512 MQA
SMSL VMV T2 picture
The SMSL VMV T2 is part of the brand's high-end product range. It's an MQA CD player that also acts as a digital interface, and features an optimized clock system. It is equipped with a P.A.S.S (Precison Access Servo System) playback system that natively supports MQA-CD. The SMSL VMV T2 also supports high-resolution PCM 32bit 768kHz and DSD512 streams, as well as full MQA decoding on some of its digital inputs. In fact, its USB-C and AES/EBU inputs supporting MQA enable it to act as a true MQA decoder. It also features an I2S output via HDMI, two AES/EBU outputs, as well as a Toslink optical output and a coaxial SPDIF output. There's also an external clock input and a clock output that can be directly connected to a DAC for excellent precision in your system. A Qualcomm QCC5125 chip also makes it a high-definition Bluetooth 5.1 receiver, with support for the following codecs: aptX, aptX HD and LDAC (24bit 96kHz).
Difference between SMSL PL200 and VMV T2 CD players
The VMV T2, unlike the PL200, features I2S and AES digital outputs, as well as a complete interface for external clock and a digital processor. The PL200's only advantage is its analog outputs.
SMSL PL200 VS SMSL VMV T2
InterfaceInputs/OutputsSMSL PL200SMSL VMV T2
Analog outputsXLR ouput
RCA output
6.35mm jack headphone output
Digital inputsCD player (MQA-CD)
HD Bluetooth receiver
USB input
AES/EBU input
Digital outputsOptical Toslink and SPDIF coaxial
HDMI I2S output
Sortie AES/EBU ouput
External clock interfaceExternal clock input (BNC)
Clock interface output (BNC)
Internal digital processor
SMSL VMV T2: P.A.S.S. reading system
The SMSL VMV T2's "Precision Acces Servo System" reading system offers high reading accuracy and excellent response. An efficient anti-vibration system also prevents any potential disturbance caused by vibration. A playback mode allows you to play a disc with the cover open, for one of the most beautiful aesthetic effects. This CD player supports the MQA-CD format.
P.A.S.S reading system
MQA support
SMSL VMV T2: MQA gateway
The SMSL VMV T2 supports full MQA decoding via its USB-C and AES/EBU inputs, enabling it to act as an MQA decoder. Its USB-C input also supports high-resolution PCM 32bit 768kHz and DSD512 streams.
SMSL VMV T2: clock alignment
The integrated clock alignment function enables the reconstruction of the clock of 44.1kHz and 48kHz audio recordings, for a marked improvement in the depth of the final sound reproduction of CDs and 44.1kHz and 48kHz recordings.
Clock alignment
SMSL VMV T2: clock input and output
An external clock input lets you connect a 44.1MHz clock, a 10MHz stantard clock or an atomic clock to the SMSL VMV T2. An output is also available for connecting the SMSL VMV T2 clock directly to a DAC, for example. The impedance of the clock input can be set to 50 ohms or 75 ohms.
Clock input/output
SMSL VMV T2: Bluetooth 5.1
The SMSL VMV T2 features a Qualcomm QCC5125 Bluetooth 5.1 receiver chip, enabling it to support high-definition codecs: SBS, AAC, aptX, aptX HD and LDAC. The LDAC codec can transmit streams up to 24bit 96kHz, for unrivalled sound reproduction in wireless transmission.
SMSL VMV T2 overview
SMSL VMVT2 overview
1Player cover
2CD retaining cap
3CD holder
4IR receiver
5Indicator LED
6Next/standby (long press)
7Previous
8Stop/Input selector (long press)
9Play/pause
10Display
11Bluetooth antenna
12USB-C input
13I2S output via HDMI
14Toslink optical output
15SPDIF coaxial output
16AES/EBU output 2
17AES/EBU output 1
18AES/EBU input
19External clock input
20Clock output
21Power supply connector
Product typeCD Player MQA
Reading systemP.A.S.S
Inputs1x CD/MQA-CD player
1x USB-C
1x AES/EBU
Bluetooth
Outputs2x AES/EBU
1x I2S via HDMI
1x Optical Toslink
1x Coaxial
USB transmissionUSB 2.0 asynchronous
USB compatibilityWindows 7 / 8 / 8.1 / 10 / 11 (with driver)
MAC OSX 10.6 ou + et Linux (without driver)
Android et IOS (without driver)
Maximum output sampling rateI2S via HDMI: PCM 32bit 768kHz, DSD512
Optical Toslink, Coaxial SPDIF, / AES/EBU: 24bit 192kHz
MQA supportUp to MQAx8 (384kHz - automatically converts to 192kHz for SPDIF)
Supported Bluetooth codecsSBC, AAC, aotX, aptX HD, LDAC (24bit 96kHz)
EXTERNAL CLOCK INTERFACE
Frequency44.1kHz or 10MHz
Input impedance50 ohms or 75 ohms
WaveformSquare or sinusoidal
LevelSquare: TTL
Sinusoidal: > 1Vrms
CLOCK OUTPUT INTERFACE
Frequency44.1kHz or 48KHz (depending on audio source)
44.1kHz (for CDs and DSD)
Output impedance75 ohms
LevelTTL
Power supply100-240V AC
Energie consumption15W
Standby: < 0.5W
Dimensions280 x 51 x 236mm
Weight3.52kg
Package1x SMSL VMV T2
1x Antenne Bluetooth
1x Câble d'alimentation
1x Câble USB
1x Télécommande
Configuration of I2S output via HDMI
Two modes are available for I2S audio output via HDMI for greater compatibility with different DACs.
I2S via HDMI output
SMSL VMV T2 measurements
The SMSL VMV T2 is part of the brand's high-end product range. It's an MQA CD player that also acts as a digital interface, and features...
