THINKYA JA-310 CD and Audio Files Player USB Optical Jack 3.5mm Bluetooth 5.1
The Thinkya JA-310 is a compact, attractive CD player that also acts as a USB file player. With its blend of vintage and modern aesthetics, it is both an excellent audio device and a beautiful decorative object, which will blend effortlessly into any living room.
4.6 / 5
Reference : 18020
59,90 €tax incl.
49,92 € tax excl.
Shipping date: 22-04-2025.
THINKYA JA-310
The Thinkya JA-310 is a compact, attractive CD player that also acts as a USB file player. With its blend of vintage and modern aesthetics, it is both an excellent audio device and a beautiful decorative object, which will blend effortlessly into any living room. Its 12.7mm-thick MDF wood and plastic casing effectively reduce vibrations. In terms of connectivity, the Thynkya JA-310 features a USB-A (USB Host) input for connecting a storage device (MP3 files only), as well as a Toslink SPDIF optical output and a 3.5mm jack output. The turntable also incorporates a Bluetooth 5.1 chip, making it capable of wireless transmission of the audio stream to a receiving device, such as an amplifier or Bluetooth speakers.
Simple control buttons
The Thynkya JA-310 is equipped with an operating mode selector, a volume control and the usual play/pause, stop, previous and next controls, all integrated into the casing.
Thinkya JA-310 back panel
Product typeCD and audio file player
Headphone / Bluetooth amplification chipAOP4558 + PAM8908
MCUServo Samsung chip
Supported formatsCD-DA
MP3 (CDR-RW / USB) / FAT32
Bluetooth transmission codecsSBC (A2DP V1.3)
InputsCD
USB-A (USB Host)
Outputs1x 3.5mm jack
1x Optical Toslink
1x Bluetooth 5.1
SNR80db
Power supply5VDC 1A via USB-C (sold separately)
Dimensions131 x 157 x 28mm
Weight310g
Package1x Thinkya JA-310
1x USB-A to USB-C Cable
8 reviews
THINKYA JA-310 CD
The player looks quite nice considered the price.
It connects via toslink to a pair of Klipsch "the fives" and audio quality it's excellent for my taste, much better then the same songs played via BT from my phone to the same speakers.
I give 4 stars because after I have bought the player i discover that a newer version is already out (JA-310R) at same price and include an infrared remote
This review has been posted for THINKYA JA-310 CD and Audio Files Player USB Optical Jack 3.5mm Bluetooth 5.1
THINHYA JA 310
utilisé avec une sortie optique toslink sur un ampli : son impeccable. L'appareil est bien fini , il fait bien son job. Il y a un petit afficheur bien visible indiquant piste et temps écoulé, situé sous le couvercle. L'objet est compact. Le bruit de rotation est très léger. C'est du made in China ( le prix !) , avec une notice uniquement en chinois. Pour info, le bouton on est celui du volume qu'il faut enfoncer. Il faut ajouter une alimentation , mais audiophonics le précise bien.
Excellent sound via Toslink, but mechanical noise intrudes
The CD player produced impeccable sound when connected via Toslink to my DAC. Unfortunately intermittent mechanical noises from the laser stepping motor were audible from 3 m away, and intruded upon quiet passages in the music.
Très bon produit
Relié à mon DAC par câble toslink, fonctionne très bien. A voir la solidité sur la durée, mais c'est un transport cd qui fait très bien son travail. Je n'ai pas essayé la sorti son du lecteur, n'en ayant pas l'usage.
Excellent quality / price ratio with linear power supply
If you want best possible sound from this player you should use a linear power supply. With a cheap sync mode power supply sound was nothing special. With Audiophonics` linear power supply sound was very good. There was like a night and day difference.
The Thinkya JA-310 is a compact, attractive CD player that also acts as a USB file player. With its...
