THINKYA R01 CD and Audio File Player
The Thinkya R01 is a CD and audio file player with a retro look. It features a SILAN SC6137D processor and a precise laser head. In addition to allowing you to play your CD library via a 3.5mm jack line output and Toslink optical output, a 3.5mm jack headphone output is also available. This headphone output is driven by a G Class amplifier stage capable of driving headphones and IEMs with impedances from 16 to 32 ohms.
Reference : 20031
64,90 €tax incl.
54,08 € tax excl.
Shipping date: 22-04-2025.
Thinkya R01 CD and USB Audio File Player Bluetooth 5.2 Bidirectional 16bit 48kHz
THINKYA R01 picture
The Thinkya R01 is a CD and audio file player with a retro look. It features a SILAN SC6137D processor and a precise laser head. In addition to allowing you to play your CD library via a 3.5mm jack line output and Toslink optical output, a 3.5mm jack headphone output is also available. This headphone output is driven by a G Class amplifier stage capable of driving headphones and IEMs with impedances from 16 to 32 ohms. Added to this is bi-directional Bluetooth 5.2 functionality, enabling a wireless signal to be received, for example, from a smartphone with streaming platforms, or sent wirelessly to a Bluetooth speaker. In addition, a USB-A (USB Disk) input lets you connect a USB stick, and accepts a wide range of formats: FLAC, APE, WAV, AAC. The whole unit is powered via USB-C port and features a 2000mAh battery for 6h autonomy.
Thinkya R01: Bluetooth 5.2
A special feature of the Thinkya R01 CD player is its two-way Bluetooth capability. Not only can it act as a Bluetooth receiver, but also as a transmitter. This can be particularly useful for people with wireless speakers.
THINKYA R01 Bluetooth functionality
THINKYA R01 USB-A input
Thinkya R01: USB-A port (Disk)
A USB port lets you use a USB stick as a source, and accepts high-definition formats: FLAC, APE, WAV, AAC.
Thinkya R01: 2000mAh battery
The Thinkya R01 is powered by a 5V/1A DC USB-C port. In addition, a 2000mAh battery provides up to 6 hours of autonomy.
THINKYA R01 battery
Thinkya R01: vintage look
This CD player has a wooden body for a very attractive effect. There's also a fader-operated digital volume control.
The attractive look of the THINKYA R01
Remote control for the THINKYA R01
Thinkya R01 remote control
An infrared remote control is supplied for a pleasant user experience. Tone control of bass and treble is available via the remote control.
Thinkya R01 overview
1CD player
2Control buttons
3Volume control
4Screen
5Power on
6Optical Toslink output
7USB-A input (USB Disk)
8Jack 3.5mm headphone output
9Jack 3.5mm line output
10USB-C charging port
Type de produitLecteur CD et de fichiers audio USB
ProcessorSILAN SC6137D
InputsCD player
1x USB-A (USB Ddisk)
Bluetooth
Outputs1x Optical Toslink
1x Line output 3.5mm jack
1x 3.5mm jack headphone output
Bluetooth
Bluetooth versionBluetooth 5.2 bidirectional
Supported formatsCD : CD-DA, CD-R, CD-RW, MP3
USB : FLAC, APE, WAV, AAC
Supported sample ratesPCM up to 16bit 48kHz
SNR> 80dB
Recommanded headphone output impedance16-32Ω
Tone controlTreble : ±10dB
Bass : ±10dB
Power supply5V DC 1A via USB-C
Standby consumption< 0.5W
Battery2000mAh
Full battery charge time3h
Battery life6h
Dimensions195 x 160 x 43mm
Weight630g
Package1x Thinkya R01
1x USB-A to USB-C cable
1x 3.5mm jack to 3.5mm jack cable
1x IR remote control
Fantastic CD player
This a great hifi budget !!! Small but with lots of outputs. The sound is very nice. Is fragile in some ways but with proper care it will last and you can have hours of audiophile sound, I connect mini with an small Fosi 331 amp and Roth speakers and it sounds so great.
This review has been posted for THINKYA R01 CD and USB Audio File Player Bluetooth 5.2 Bidirectional 16bit 48kHz
The Thinkya R01 is a CD and audio file player with a retro look. It features a SILAN SC6137D processor and a precise laser head. In addition to...
