PCB / Circuit board terminals 4 poles gold plated
This gold-plated 4 screw terminal block allows simple, reliable and fast connection for all printed circuit boards requiring voltage and current (300V 25 A).
Reference : 12580
1,90 €tax incl.
1,58 € tax excl.
Shipping date: 16-04-2025.
Terminals gold plated brass for electronic touch gold plated phoenix circuits
Screw terminals gold plated
These screw terminals 4 Gold plated terminals to use for printed wiring circuit / PCB and allow through a single screw connecting the card and the wiring. It provides reliable contact quality and a simple and clean solution to any component mounting ..
Once welded on the map it remains only screw the cable.
Stackable
Stacking Blocks gold plated electronic snap
To follow the development of your construction projects, these terminals can be assembled with each other. We can therefore easily adjust the number of locations while maintaining stability and optimum robustness of the electronic assembly.
It can be stacked with this 2 posts model of IC connector as well.
Dimensions
electronic connector terminal size 4 gold plated audiophile locationDimensions screw and depth connector for integrated circuit
Characteristics
Overall width (with latch)40.5 mm
Width39.5 mm
Overall height (with pins)23.7 mm
Housing height14.5 mm
Housing Depth14.2 mm
Pin Height9.2 mm
Pin spacing10 mm
Pin width1 / 1.8 mm
Screw Diameter6.6 mm
Max terminal width8 mm
ConductorGold-plated brass
Connectorsx4
Electrical Specs300V 25A
StackableYes
Sold individuallyYes
ConnecticN/A
Contacts number4
This gold-plated 4 screw terminal block allows simple, reliable and fast connection for all printed circuit boards requiring voltage and current...
