JANTZEN AUDIO COMPACT MKT 001-8080 MKT Capacitor 160V 6.8µF
JANTZEN AUDIO COMPACT MKT 001-8080 Axial MKT Capacitor 160V 6.8µF
Jantzen Audio's Compact MKT capacitors are made from the highest quality metallized polyester film available. Jantzen Audio has succeeded in making these capacitors more compact and giving them better sonic properties than standard film capacitors. With a nominal voltage of 160V DC, these capacitors are also more versatile than electrolytic capacitors.
Reference : 18726
2,00 €tax incl.
1,67 € tax excl.
Shipping date: 15-08-2024.
Jantzen Audio Compact MKT 001-8080 Axial MKT Capacitor 160V 6.8µF
Jantzen Audio's Compact MKT capacitors are made from the highest quality metallized polyester film available. Jantzen Audio has succeeded in making these capacitors more compact and giving them better sonic properties than standard film capacitors. With a nominal voltage of 160V DC, these capacitors are also more versatile than electrolytic capacitors, whose nominal voltage is usually only 63V DC or 100V DC. Thanks to their rounded square shape (flat top and bottom surface), they can be easily stacked when it's necessary to couple several capacitors in parallel to achieve a higher capacitance value for a certain crossover position. Stackable, they also take up much less space than equivalent round values.
Technical characteristics
Capacitor typeMKT axial compact capacitor
Voltage rating160VDC
100VAC
Capacity tolerance±5%
Capacity6.8µF
Capacitor foilMetallized polyester foil
Dielectric insulationPolyester foil
Terminal leadsTinned 4N copper wire
Dielectric absorption factor< 0.5% @ 20°C
Dielectric thickness5µm
ESRExtremely low
Dissipation factorExtremely low
Self-inductance< 15nH
Temperature range-55°C / +125°C
Metal layer thickness0.3µm
Metal layer conductivity1.2Ω/cm²
Dimensions (L x P x H)31 x 17 x 12mm
ColorWhite
Tolerance (%)5
Capacitor capacitance (µF)6.8
Rated voltage (V)160.0
Rated voltage (V)100.0
Capacitor typeFilm capacitor
Capacitor formatAxial
Excellent
Pour remplacement des médiums aigus sur filtre enceintes Cabasse Doris M2, en lieu et place des condensateurs d'origine Wishay MKT 1822 (verts). Le résultat est très bon. Les médiums et aigus retrouvent leur place. Les voix initialement criardes retrouvent leur ton (surtout les voix masculines, qui n'avaient pas de caractère et manquaient de texture). Les instruments et voix sont mieux placés et respirent. Ce n'est serte pas aussi dynamique, explosif et aéré qu'avec des Jantzen sup Z que j'ai monté sur des Dali Zensor 7, mais je dois dire que je suis assez surpris par la qualité. Pour ma part je trouve supérieure aux Jantzen cross cap et z cap. Ils sont plus neutres. leur valeur est exactement celle indiqué à 0,01micro farad près gage de qualité de fabrication. Cerise sur le gâteau si vous ne voulez pas vous torturer pour trouver une place sur le filtre, ils sont de taille modeste. Environ la même que ceux qu'ils remplacent.
This review has been posted for JANTZEN AUDIO COMPACT MKT 001-8080 Axial MKT Capacitor 160V 6.8µF
Jantzen Audio's Compact MKT capacitors are made from the highest quality metallized polyester film available. Jantzen Audio has succeeded in...
