BURSON AUDIO SUPREME SOUND OPAMP V5i Dual OPA Hybrid DIP8 (Unit)
The Burson V5i is a hybrid audio AOP, integrating both integrated circuits and discrete components for exceptional performance. It bears the signature sound of its big brother, the V5, considered by many as the reference in the world of audio.
4.8 / 5
Reference : 13151
59,90 €tax incl.
49,92 € tax excl.
Shipping date: 30-04-2025.
BURSON SUPREME SOUND OPAMP V5i
Dual OPA DIP8 (Unit)
Hybrid Audio OPA with SSV5 DNA
Burson's latest PDO is the result of a partnership with a leading microchip manufacturer. So, with this alliance they created a new version of their V5 FET circuit. Moreover, in order to overcome certain limitations inherent in integrated circuits, they outsourced certain parts of their circuits and completed them with very high quality discrete components.
This V5i from Burson is the result of these collaborations. It is a hybrid audio PDO, integrating both integrated circuits and discrete components. In addition, it bears the sound signature of its big brother, the V5, considered by many as the reference in the world of audio.
Burson Supreme Sound Opamp V5i Double
Practical and Efficient
With this V5i, Burson offers a PDO similar in size to a classic PDO and also with DIP8 support. Thus, it will be extremely easy to integrate into devices that also have DIP8 support and its size will not be a problem. Despite its contained size, the V5i offers exceptional performance.
Incredible performance and quality
The V5i has a bandwidth of up to 50MHz. If these very high frequencies are not audible by the human ear, they participate in the listening of a piece to the general feeling and the richness of the restitution. And just like its big brother the discreet V5, the V5i offers dynamic, transparent reproduction and a wide sound image.
Will the V5i work on your device?
BEFORE INSTALLING AN OPA
In order to know if the OPA V5i will work on your device, here are some steps to realize :
  • Identify the PDO(s) in your device.
  • Verify that it is really an integrated circuit with 8 pins as on the picture below.
  • Note the model of the PDO(s) of your device.
  • Find pine 1 thanks to the semi-circle indicator (in blue on the picture below).
  • Determine if you need a single or Dual PDO.
Installation
1. Make sure you have the right PDO
  • V5 OPA-D = Dual OPA = can replace a dual OPA
  • V5 OPA-S = Single OPA = can replace a signle OPA
2. Connect the OPA in the correct direction:
Align the half circle of the PCB or IC support with the half circle of the V5i OPA.
An OPA connected in the wrong direction has a very high chance of being destroyed. An operating error is not covered by the warranty.
Compatibility
The Burson Dual V5i OPA is compatible and therefore interchangeable with the following OPA:
AD823, AD823AN, AD8066, AD8620, AD712, AD827, C4570, JRC4556AD, JRC4580, JRC5532, JRC5532D, JRC5534, LF353, LM4562, LME49860, LM833N, MUSES8920, NE5532, NEC4520, NEC4570, NJM2068D, NJM2114, NJM2214D, NJM4558, NJM4558D, NJM4560, NJM5532, NJM4558P, OP275, OPA1612, OPA2277PA, OPA2132, OPA2134, OPA2604, JRC4558, RC4558D, RC4558P, TL052, TL072, MUSES01, MUSES02, MUSES8820, MUSES8920, MUSES8832, BA15532.
ModelDual V5i
Connection typeDIP8
Dimensions11 x 11 x 7.3mm
Quantity;1 - Unit
Absolute maximum ratings
DescriptionMinTypMax
Supply voltage+/-5V / 10VDC-+/-16V / 32VDC
Operating ambiant temperature-25°C-60°C
Storage temperature range-65°C-85°C
DC Characteristics
DescriptionConditionsMinTypMax
Quiescent current--10mA-
Input offset voltageRS = 00.05mV3mV-
Input offset current-0.02µA2µA3µA
Input BIAS current-1.2µA3µA4µA
CMRR--100dB-
PSRR--90dB-
AC Characteristics
Open loop gain--70dB-
Open loop bandwidthRL = 600 Ohm-45kHz-
Gain bandwidth product@ 100kHz-50MHz-
Slew ratef = 10kHz, RS = 2 KOhm45V/µS-50V/µS
Input resistance--45 MOhm-
Crosstalk distorsionf = 1kHz, RS = 600 Ohm-> 95dB-
THD1kHz @ 2V, RL = 600 Ohm-0.005%-
Output impedanceAV = 30dB closed loop f = 10kHz, RL = 600 Ohm-0.5%-
OPA TypeDual
9 reviews
Changed to XDUOO XD 05 BASIC. I listened with the Edifier S2000MKIII, AKG K371, BQEYZ Spring2.
Subjective opinion: the sound is softer, more balanced. The whole range is kind of longer, the edges (low and high) have become stronger and more detailed. I recommend you give it a try.
Thank you
This review has been posted for BURSON AUDIO SUPREME SOUND OPAMP V5i Dual OPA Hybrid DIP8 (Unit)
Good opa
Hello,
I bought it and tested it on the Fostex Hp A3.
It was better than the chip I used.
The sound stays warm, more midrange and defined bass, I found it better than the Au 627, it was more fun to play and the resolution and detail was excellent.
I found it better than the new generation Vivid models, because it is simply more authentic in the reproduction. compared to the Vivid the Red Opa was too bright in the treble.
Definitely worth it if you have the opportunity to replace the Opa.
excellent
I replaced the original op amp of my dac x-duoo xd05 plus, it added a more spacious and dynamic sound, now is a bit less warm but clear and natural, very pleasant. Good purchase and good service, I received the package in a few days
Rroels
Nous sommes deux a avoir testé cet AOP, sur deux dac similaires de chez audiophonics et d autres fabricants utilisant le même AOP
Musical ,mais produit trop audiophile, manque d ouverture,les ambiances de salles,les instruments son bien reproduits mais avec une certaine retenue, manque de lisibilité dans les extrêmes,manque de naturel,décevant..........
Le LME 49720 HA, est plus exubérant ( peut être trop......), mais beaucoup plus réaliste sur les timbres et la restitution des différents lieux d enregistrement , plus vivant, plus rapide
A méditer!!!!!!!
Est-ce aussi "supreme sound" que son nom le laisse l'entendre ?
Testé sur couple Hifiman 4xx + Xduoo XD-05 Plus en remplacement de l'AOP d'origine. N'en déplaise à certains mais personnellement je n'ai constaté aucune amélioration notable sur l'ensemble du spectre sonore, d'ou le 3 étoiles. A l'instar de l'AOP d'origine qui a une rendu exceptionnel, avec cette ouverture et une précision remarquable qui doit être propre à l’AOP d’orgine, le Burson lui ajoute un voile et vient dénaturer (boucher) l'écoute, la rendant moins précise, moins exceptionnelle. Pas top du coup ! Ceci dit, avec le Burson on remarque effectivement des changements assez importants sur certains instruments, notamment la grosse caisse ou la caisse claire, les rendant plus percutants, plus énergique, les cordes sont également transformées de la même manière. Est-ce en bien ou en mal je suis incapable de le dire, mais c'est sûr que ça "claque" un peu plus avec le Burson et tous les "effets" ajoutés à la musique sont un peu plus "marqués". Cependant, j'ai remis l'AOP d'origine car après quelques heures d'écoutes je me suis rendu compte que "quelque chose" manquait et cela s’est immédiatement manifesté par une disparition du voile, redonnant toute sa splendeur à l'écoute de mon Hifiman avec ce Xduoo. Quelle précision ! Quelle ouverture ! Comment s’en passer ? Hop retour dans sa boite le Burson, dommage. Pour conclure Je ne peux donc pas affirmer que ce changement d'AOP soit bénéfique à tout le monde en ajoutant vraiment quelque chose à la qualité finale du rendu.
 (5)
The Burson V5i is a hybrid audio AOP, integrating both integrated circuits and discrete components for exceptional performance. It bears the...
