AUDIO-GD JZ1 Type 3 Clock Low Jitter 24.57MHz TCXO
Reference : 6225
47,90 €tax incl.
39,92 € tax excl.
This small circuit makes it possible to general an MCLK signal and to inject it in the circuit of your choice
First class, it incorporates a class A power supply and a TCXO
This frequency of 24.576Mhz is generally used to operate with a sampling rate of 48kHz, 96kHz and 192kHz
Characteristics :
  • JZ1 Low Jitter Clock
  • Type 3: 24.576MHZ (Some Decks DVD / SACD)
  • Power supply: 8 - 20V DC
  • Accuracy: +/- 0.3ppm
  • Accuracy depending on temperature: +/- 1ppm
  • Noise: -125dBc / 1kHz @ 10MHz
  • Stability over time: 2ppm / year
  • Power Consumption: 60mA
  • Error Rate: 1.0 ps RMS (test @ 1 / 4fo TCXO version)
  • Dimensions of the PCB: 70x45x25mm (L x W x H)
  • Output voltage: from 3.3 to 5V
  • Weight: 40g
https://www.audiophonics.fr/images2/6223/6223_AUDIOGDJZ1_1.jpg
