CRYSTEK Ultra-Low Phase Noise Clock 24.576MHz 3.3V 25ppm HCMOS
These clock oscillators, which can be used in particular for mounting DAC, ADC or a signal source, ensure very low phase noise.
Reference : 12446
19,90 €tax incl.
16,58 € tax excl.
Shipping date: 16-04-2025.
CRYSTEK CCHD-575 - CLOCK
24.576MHz 3.3V 25ppm 5x7.5mm HCMOS
Crystek oscillateur horloge
This series of Crystek clocks offers the lowest jitter oscillators for a 5x7.5mm format. These clocks provide a phase jitter of 82fSec RMS at 100MHz. Their phase noise is -90dBc/Hz @ 10Hz for a minimum of -168 dBc/Hz. Its output driver is capable of driving ±24mA. This translates to a rise/fall time of approximately 600ps at 100 MHz with a load of 15pF.
These clock oscillators can be used to mount DACs or ADCs, low phase signal sources or for tests and measurements.
This version of 24.576Mhz is designed for 48kHz, 96Khz multiples.
Crystek Clock Oscillator Datasheet
Frequency24.576MHz
Frequency stability25ppm
Load Capacity15pF
Operating supply voltage3.3V
Output formatHCMOS
Connection typeSMD/SMT
Dimensions7.5mm x 5.08 x 2.5mm
Minimum Operating Temperature-20°C
Maximum operating temperature+70°C
Rating current25mA
