IAN CANADA CCHD957 Adapter Supports for XO Clocks and SMT Capacitors (x2)
This DIY kit CCHD957 from Ian Canada includes two PCBs and the PCB connector for mounting XO clocks and SMT capacitors on supports. These supports allow the XO SMT capacitor clocks to be adapted to certain audio modules with the necessary connectivity.
Reference : 13825
12,50 €tax incl.
10,42 € tax excl.
Ian Canada CCHD957
Ian Canada CCHD957 Supports Adaptateurs pour Horloges XO (x2)
The proper use of this DIY kit requires knowledge of electronics. Improper installation could affect the proper functioning of the product and the device on which it is mounted.
Mounting
To mount XO clocks and capacitors, follow the following steps:
1. Assemble the CCHD957 with an XO clock or SMT capacitor according to your connection diagram.
2. Remove the gold plated contacts from the supplied SIP connector.
3. Insert the pins previously obtained on the PCB. Insert the pins from above (see picture below).
4. Connect the pins on the extension in the opposite direction. Solder the bottom part of the PCB.
5. Check that the gold-plated pins are assembled in the same direction as in the picture below.
6. Cut the top of the pines with a cutting pliers. The assembly is completed
6. Connect the support with the integrated component to your module (example below with Ian Canada FiFoPi and McDualXO modules).
Product typeXO Clocks and SMT capacitors support
Number of supports2
Contacts platingGold
This DIY kit CCHD957 from Ian Canada includes two PCBs and the PCB connector for mounting XO clocks and SMT capacitors on supports. These supports...
