IAN CANADA SC-PURE Femtosecond Clock Ultra-Low Phase Noise 22.5792MHz
Ian Canada's SC-Pure is a high-end audiophile clock made from high-quality SC-CUT crystals. An advanced oscillator architecture has been developed to achieve the best performance in terms of phase noise. Sound quality can thus be significantly improved by replacing a conventional clock with an SC-Pure in DACs or network players, for example.
By buying this product you get 22 loyalty points
Reference : 18230
225,00 €tax incl.
187,50 € tax excl.
Shipping date: 16-04-2025.
Ian Canada SC-Pure
Ian Canada SC-Pure Horloge Femtosecond Ultra-Faible Bruit de Phase
Key features:
  • SC-CUT crystals.
  • Specially designed pure sinusoidal topology introduced to convert very high-purity sinusoidal signals into square waves directly from the SC-CUT crystal resonator, bypassing any active components. The result is the best possible phase noise performance.
  • The SC-Pure's very low close phase noise and phase background noise enable it to compete with any high-end clock.
  • Femtosecond phase jitter.
  • Compact standard DIP14 format with 3.3V supply voltage and LVCMOS output. Plug & Play. Quick and easy installation.
  • Standby function to eliminate interference on unselected frequencies.
  • Dual shielding housings on the top and bottom of the PCB for enhanced protection against electromagnetic interference (EMI).
  • A 3.3V supercapacitor or LiFePO4 battery can be used to optimize performance. Also features an LED power indicator.
Product typeClock
Frequency22.5792MHz
Phase noise-65.48dBc/Hz @ 0.1Hz Offset
-91.82dBc/Hz @ 1Hz Offset
-120.85dBc/Hz @ 10Hz Offset
-147.91dBc/Hz @ 100Hz Offset
-160.03dBc/Hz @ 1kHz Offset
-166.01dBc/Hz @ 10kHz Offset
-166.19dBc/Hz @ 100kHz Offset
-168.52dBc/Hz @ 1MHz Offset
-167.79dBc/Hz @ 10MHz Offset
Phase jitter47.59fs @ 10Hz-1MHz
124.2fs @ 10kHz-10MHz
Ian Canada's SC-Pure is a high-end audiophile clock made from high-quality SC-CUT crystals. An advanced oscillator architecture has been...
