IAN CANADA SC-PURE Femtosecond Clock Ultra-Low Phase Noise 45.1584MHz
Ian Canada's SC-Pure is a high-end audiophile clock made from high-quality SC-CUT crystals. An advanced oscillator architecture has been developed to achieve the best performance in terms of phase noise. Sound quality can thus be significantly improved by replacing a conventional clock with an SC-Pure in DACs or network players, for example.
By buying this product you get 22 loyalty points
Reference : 18253
225,00 €tax incl.
187,50 € tax excl.
Shipping date: 16-04-2025.
Ian Canada SC-Pure
Ian Canada SC-Pure Horloge Femtosecond Ultra-Faible Bruit de Phase
Key features:
  • SC-CUT crystals.
  • Specially designed pure sinusoidal topology introduced to convert very high-purity sinusoidal signals into square waves directly from the SC-CUT crystal resonator, bypassing any active components. The result is the best possible phase noise performance.
  • The SC-Pure's very low close phase noise and phase background noise enable it to compete with any high-end clock.
  • Femtosecond phase jitter.
  • Compact standard DIP14 format with 3.3V supply voltage and LVCMOS output. Plug & Play. Quick and easy installation.
  • Standby function to eliminate interference on unselected frequencies.
  • Dual shielding housings on the top and bottom of the PCB for enhanced protection against electromagnetic interference (EMI).
  • A 3.3V supercapacitor or LiFePO4 battery can be used to optimize performance. Also features an LED power indicator.
Product typeClock
Frequency45.1584MHz
Phase noise-56.42dBc/Hz @ 0.1Hz Offset
-84.38dBc/Hz @ 1Hz Offset
-113.49dBc/Hz @ 10Hz Offset
-143.32dBc/Hz @ 100Hz Offset
-162.15dBc/Hz @ 1kHz Offset
-167.81dBc/Hz @ 10kHz Offset
-169.04dBc/Hz @ 100kHz Offset
-169.02dBc/Hz @ 1MHz Offset
-169.56dBc/Hz @ 10MHz Offset
Phase jitter29.71fs @ 10Hz-1MHz
53.73fs @ 10kHz-10MHz
5 reviews
Retour d'expérience après rodage - environ 50H
Je tenais à faire un petit retour d'écoute de ces horloges au combien excellentes, cependant après rodage de celles-ci (45 et 49 MHz) installées sur mon Reclocker FIFO PI Q7 II, il apparait ce qui suit :
- Les voix de certains chanteurs étaient auparavant un petit peu sourdes , elles sont bien en place après rodage.
- Tout parait beaucoup plus juste, plus à sa place.
- On gagne de la matière dans le bas médium
- Les graves sont abyssales et très tendus
- Les fins de notes sont hyper silencieuses
Pour finir le plus important, il y a une séparation des canaux et des instruments encore plus marqué, j'ai une stéréophonie qui prend de la largeur comme jamais. Et puis tout ça c'est très naturel, sans crispation ni dureté on en oubli que c'est du numérique !! Produit à acheter pour atteindre les sommets (auparavant j'avais des horloges Accusillicon), le gap est vraiment important entre ces deux horloges !! Bravo à Ian Canada pour le développement de leurs produits qui sont bien au-dessus de la concurrence.
This review has been posted for IAN CANADA SC-PURE Femtosecond Clock Ultra-Low Phase Noise 45.1584MHz
Upgrade horloge Accusilicon vers SC Pure
Petit retour d'expérience sur cette nouvelle horloge SC Pure de chez Ian Canada. En effet, dans mes autres post sur mon streamer audio à base de produits Ian Canada je ne suis pas déçu de ce changement d'horloge !! Même si l'apport en qualité n'est pas aussi flagrant, il y a tout de même un petit gap avec ce qui suit :
- Une amélioration de la scène sonore (plus d'espace)
- Une dynamique plus grande
- Une séparation des instruments et surtout des voix
- Des fins de notes plus silencieuses
- Des voix plus naturelles et très charnelles
- Des graves très tendus et très propres
- des micro détails très lointains auparavant qui se détachent nettement
- Un son très analogique sans les effets du numérique et sans les inconvénients de l'analogique
A noter que dans cet uprgrade j'ai aussi mis des supercondos en sortie de l'alimentation 5V régulée Linéar PI de chez Ian Canada pour alimenter le reclocker FIFO PI Q7 II.
Il est donc difficile de dire si c'est l'horloge qui l'emporte sur cet upgrade ou l'ajout des supercondos.
Dans tous les cas après lecture de bien des avis sur les forums concernant les DACs, les Reclokers, les alimentations ou les horloges et après avoir vérifié par moi même en upgradant petit à petit mon streamer audio (cela m'a pris 2 ans et ce n'est pas fini) à base de Raspberry 4 avec des produits de chez Ian Canada. Il y a à chaque fois une amélioration de la qualité sonore du système qui est très nette à condition d'avoir des enceintes capables de révéler ces différences. Pour ma part je suis en Haut Rendement, bi-amplifé avec en amont un filtre actif Najda tweaké muni de sorties analogiques épaulé par des Ampli OP de compétition de chez Sparkos Labs (les plus haut de gamme, du pure class A). Pour les HP Altec 414 Z (30 cm) , chambre de compression TAD 2001 (membrane Béryllium d'origine) + Pavillon DIY (tournage CNC).
Pour finir beaucoup de passionnés se chifonnent sur les forums de discussion pour affichier leurs préférence bec et ongle concernant tel ou tel Dac. Après avoir écumé beaucoup d'info à ce sujet j'ai retenu ce qui suit chaque d
Jean-François.
Révolution de l'Expérience Musicale Audiophile
L'horloge IAN Canada a transformé mon expérience musicale. Remplaçant l'ancien dans mon DMP-A6 Master, il a nettement amélioré la qualité sonore, éliminant les distorsions pour révéler la richesse de chaque note. Sa fabrication de qualité et le service client exemplaire ont également impressionné. Je recommande vivement ce bijou audiophile à quiconque cherche à améliorer son système audio pour une expérience d'écoute captivante et immersive.
No words!
First of all, I put a single clock on Ian Canada's dualxo board, with a very good linear feed and Ian Canada's ADM715X regulator. The result was very good: the scene was clearly going forward and upwards, more air between the instruments and more detail, the reverberations of the recording were especially noticeable.
After improving the feeding with Ian Cada Lifepo4 and UCconditioner MKII the change has been even more spectacular, highlighting that there is still more clarity in the recordings, and my system is already very transparent, but what stands out the most is the considerable increase in bass. I have a system with coxial speakers and ripol subwoofer, the theory says that I should not have a seismic bass, typical of closed boxes, but surprisingly and inexplicably it has appeared with the change of power. I have to say that my system is very good and I have some amazing speaker cables, I don't know if the effect on more modest systems can be just as good.
Simply excellent !
worth every penny ....
Ian Canada's SC-Pure is a high-end audiophile clock made from high-quality SC-CUT crystals. An advanced oscillator architecture has been...
