IAN CANADA SC-PURE Femtosecond Clock Ultra-Low Phase Noise 49.1520MHz
Ian Canada's SC-Pure is a high-end audiophile clock made from high-quality SC-CUT crystals. An advanced oscillator architecture has been developed to achieve the best performance in terms of phase noise. Sound quality can thus be significantly improved by replacing a conventional clock with an SC-Pure in DACs or network players, for example.
By buying this product you get 22 loyalty points
Reference : 18254
225,00 €tax incl.
187,50 € tax excl.
Shipping date: 29-07-2025.
Ian Canada SC-Pure
Ian Canada SC-Pure Horloge Femtosecond Ultra-Faible Bruit de Phase
Key features:
  • SC-CUT crystals.
  • Specially designed pure sinusoidal topology introduced to convert very high-purity sinusoidal signals into square waves directly from the SC-CUT crystal resonator, bypassing any active components. The result is the best possible phase noise performance.
  • The SC-Pure's very low close phase noise and phase background noise enable it to compete with any high-end clock.
  • Femtosecond phase jitter.
  • Compact standard DIP14 format with 3.3V supply voltage and LVCMOS output. Plug & Play. Quick and easy installation.
  • Standby function to eliminate interference on unselected frequencies.
  • Dual shielding housings on the top and bottom of the PCB for enhanced protection against electromagnetic interference (EMI).
  • A 3.3V supercapacitor or LiFePO4 battery can be used to optimize performance. Also features an LED power indicator.
Product typeClock
Frequency49.1520MHz
Phase noise-56.67dBc/Hz @ 0.1Hz Offset
-84.98dBc/Hz @ 1Hz Offset
-112.70dBc/Hz @ 10Hz Offset
-142.92dBc/Hz @ 100Hz Offset
-161.76dBc/Hz @ 1kHz Offset
-167.02dBc/Hz @ 10kHz Offset
-168.07dBc/Hz @ 100kHz Offset
-168.09dBc/Hz @ 1MHz Offset
-168.79dBc/Hz @ 10MHz Offset
Phase jitter29.89fs @ 10Hz-1MHz
54.36fs @ 10kHz-10MHz
8 reviews
Great upgrade
Installed in a Transport Pi Digi that sits on top of an Isolator Pi III with the Pure PI PSU. RPi 3 running Gentoo Player and Diretta.
Adding the SC Pure clocks significantly improves all areas. I most noticed vocals, it removes that digital taint.
When I first got my Sennheiser 800S I really didn't enjoy them. After 'fixing' the digital transport I love them.
This review has been posted for IAN CANADA SC-PURE Femtosecond Clock Ultra-Low Phase Noise 49.1520MHz
Sc Pure après rodage d'environ 50h00
Je tenais à faire un petit retour d'écoute de ces horloges au combien excellentes, cependant après rodage de celles-ci (45 et 49 MHz) installées sur mon Reclocker FIFO PI Q7 II, il apparait ce qui suit :
- Les voix de certains chanteurs étaient auparavant un petit peu sourdes , elles sont bien en place après rodage.
- Tout parait beaucoup plus juste, plus à sa place.
- On gagne de la matière dans le bas médium
- Les graves sont abyssales et très tendus
- Les fins de notes sont hyper silencieuses
Pour finir le plus important, il y a une séparation des canaux et des instruments encore plus marqué, j'ai une stéréophonie qui prend de la largeur comme jamais. Et puis tout ça c'est très naturel, sans crispation ni dureté on en oubli que c'est du numérique !! Produit à acheter pour atteindre les sommets (auparavant j'avais des horloges Accusillicon), le gap est vraiment important entre ces deux horloges !! Bravo à Ian Canada pour le développement de leurs produits qui sont bien au-dessus de la concurrence.
Upgrade horloge Accusilicon vers SC Pure
Petit retour d'expérience sur cette nouvelle horloge SC Pure de chez Ian Canada. En effet, dans mes autres post sur mon streamer audio à base de produits Ian Canada je ne suis pas déçu de ce changement d'horloge !! Même si l'apport en qualité n'est pas aussi flagrant, il y a tout de même un petit gap avec ce qui suit :
- Une amélioration de la scène sonore (plus d'espace)
- Une dynamique plus grande
- Une séparation des instruments et surtout des voix
- Des fins de notes plus silencieuses
- Des voix plus naturelles et très charnelles
- Des graves très tendus et très propres
- des micro détails très lointains auparavant qui se détachent nettement
- Un son très analogique sans les effets du numérique et sans les inconvénients de l'analogique
A noter que dans cet uprgrade j'ai aussi mis des supercondos en sortie de l'alimentation 5V régulée Linéar PI de chez Ian Canada pour alimenter le reclocker FIFO PI Q7 II.
Il est donc difficile de dire si c'est l'horloge qui l'emporte sur cet upgrade ou l'ajout des supercondos.
Dans tous les cas après lecture de bien des avis sur les forums concernant les DACs, les Reclokers, les alimentations ou les horloges et après avoir vérifié par moi même en upgradant petit à petit mon streamer audio (cela m'a pris 2 ans et ce n'est pas fini) à base de Raspberry 4 avec des produits de chez Ian Canada. Il y a à chaque fois une amélioration de la qualité sonore du système qui est très nette à condition d'avoir des enceintes capables de révéler ces différences. Pour ma part je suis en Haut Rendement, bi-amplifé avec en amont un filtre actif Najda tweaké muni de sorties analogiques épaulé par des Ampli OP de compétition de chez Sparkos Labs (les plus haut de gamme, du pure class A). Pour les HP Altec 414 Z (30 cm) , chambre de compression TAD 2001 (membrane Béryllium d'origine) + Pavillon DIY (tournage CNC).
Pour finir beaucoup de passionnés se chiffonnent sur les forums de discussion pour afficher leurs préférence bec et ongle concernant tel ou tel Dac. Après avoir écumé beaucoup d'info à ce sujet j'ai retenu ce qui suit chaque dac a sa signature sonore avec nos préférences personnelles. Cependant même un dac qui au premier abord ne nous a pas plus peu se révéler redoutable après avoir changé les alims, les horloges, le reclocker, etc... C'est ce que j'ai pu vérifier en constuisant mon propre système, voimà pour mon avis perso.
Jean-François.
Transcendantal !
Mon DAC Musical Paradise MP-DX, propose une option d'horloge externe équipée d'origine d'une horloge Accusilicon AS338-B déjà excellente et alimentée par batterie. L'horloge externe apporte incontestablement ses qualités d'écoute. Mais j'ai voulu aller encore plus loin en remplaçant l'Accusilicon par cette horloge Ian Canada SC-Pure (49.1520 MHz). Ce fabuleux DAC MP-DX bien trop méconnu en France passe alors à un autre niveau. Il était déjà au dessus des nuages, le voilà dans les étoiles !
L'amélioration après quelques heures de fonctionnement est globale et le DAC déjà très bon devient alors incroyable ! La qualité de cette horloge est telle qu'elle est capable de transcender un DAC d'une manière étonnante.
Attention à bien repérer le bon sens de connexion, les broches sont numérotées.
this is it :)
Packaging and shipping were superb. I was really curious how these expensive clocks would hold up. They don't let down. Much better than the accusillicon. Treble/mid/bass took a giant leap.
Imaging way better :)
It is so good, so happy to have high-end sound in my living room.
Ian Canada's SC-Pure is a high-end audiophile clock made from high-quality SC-CUT crystals. An advanced oscillator architecture has been...
